Thread: injector removal
Results 1 to 6 of 6
  1. #1 injector removal
    SE Level Member Charged97's Avatar
    ATLANTA
    i seen some oil seepage round my middle injector guessing its my seal /oring how hard is it to remove and replace this part on my 97
  2. #2 Re: injector removal
    Oklahoma
    If its motor oil there, that may not be the injector, in fact, its most likely not. Its more likely that you have a leaking valve cover.
  3. #3 Re: injector removal
    Barksdale AFB, LA
    Or LIM gaskets.
    2009 Subaru Impreza WRX STI
  4. #4 Re: injector removal
    SE Level Member GTP SE's Avatar
    Ankeny, IA
    Quote Originally Posted by Sabrewings View Post
    Or LIM gaskets.
    agreed
    2001 GTP Special Edition
    |ZZP PCM|Headers|Ported LIM and blower|3.2 / 3.4 pulley|1.9's|MSD wires|Drilled 180* T stat|3" ZZP Catback l
  5. #5 Re: injector removal
    Oklahoma
    That too. LOL
  6. #6 Re: injector removal
    Feb 2008
    Yeah it's most likely an intake gasket. The fuel rail is pretty easy to remove, 4 nuts the just lift up. Caution: If your a smoker give it up while doing this as some fuel spillage should be expected. Make sure to replace all 12 of the injector o-rings. Use a light oil to lube them up when reinstalling them into the head. Good luck!!!
  1. Replacing Injector O-ring's [*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 04-25-2013, 12:48 PM
  2. Injector cleaning, yes or no?
    By Sabrewings in forum General Tech Discussion
    Last Post: 10-20-2008, 12:17 AM
  3. Fuel Injector O-ring ????
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2008, 05:16 PM
  4. SES Code after injector Upgrade
    By FastKatt in forum PCM Tuning
    Last Post: 05-13-2008, 08:27 PM
  5. No fire on #3 cyl, injector problems??
    By gplostinnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2008, 12:28 AM
