Thread: Injector removal
Results 1 to 2 of 2
  1. #1 Injector removal
    SE Level Member RobGTP's Avatar
    Jul 2010
    Massachusetts
    on an L67 motor do you have to remove the intake manifold to take the injectors out, or can u just pull the fuel rail and pop the injectors out? The car is misfiring and stuff and ive tried everything else. Its throwing a code for injector on cylinder 1 so im going to replace all the injectors.
  2. #2 Re: Injector removal
    Omaha, NE
    Release pressure from the fuel lines.
    Unbolt the fuel rail.
    Lift and wiggle slowly on the rail pulling up on the injectors as necessary OR unclip all 6 injectors and pull the rail up seperate from the injectors.
    Don't forget new O rings and make sure you clip the new injectors into the rail on the right notch so you don't have any leaks.
  1. Broken injector tip
    By FordMan77 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-06-2010, 10:55 AM
  2. Injector ?
    By CrazyGuy03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2010, 10:43 PM
  3. Injector tuning ?
    By GTP4 in forum PCM Tuning
    Last Post: 01-28-2009, 08:57 AM
  4. injector removal
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 09:43 PM
  5. Injector cleaning, yes or no?
    By Sabrewings in forum General Tech Discussion
    Last Post: 10-20-2008, 12:17 AM
