Thread: M90 flow?
Results 21 to 40 of 79
  1. #21 Re: M90 flow?
    Gee Mr. TVS thought you knew all this kind of information.......
    Im not even going to start.
  2. #22 Re: M90 flow?
    Banned
    CT
    im not convinced that you know how motors work.
    I'd like for you to personally answer both questions posed in this thread.
    How much does an M90 flow at 14,000 rpm in ci/rev?
    Why do cars make more power with intake/exhaust mods?
    Answer these correctly and I'll be very impressed.
    Hint: Both answers are directly related to a very basic fundamental.
  3. #23 Re: M90 flow?
    Charles City, IA
    How would you know the correct answer if you asked it in the first place? sounds like your being a dumb ass now.
    SMGPFC Two Nipple General
  4. #24 Re: M90 flow?
    Banned
    CT
    Quote Originally Posted by TheOtherNick View Post
    I assure you that my intent is to educate.
  5. #25 Re: M90 flow?
    Charles City, IA
    well if you know the answer enlighten us.
  6. #26 Re: M90 flow?
    Quote Originally Posted by SnowFlake View Post
    Havnt we gone over this 1000% times?
    Efficiency,
  7. #27 Re: M90 flow?
    Banned
    CT
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    Efficiency,
    Efficiency... you're almost there.
    What kind of efficiency? And can you answer how many ci/rev the M90 flows at 14,000rpm and 10psi?
    Ballpark is fine.
  8. #28 Re: M90 flow?
    Ballpark is fine.
    Your 10psi has nothing to do with any of this. The psi is restricted by the amount of air the engine can move. Which is exactly why people see less psi when adding better heads, headers, ect.
  9. #29 Re: M90 flow?
    Banned
    CT
    Actually PSI is a very relevant thing when we're talking about this efficiency. Can you please answer the question?
  10. #30 Re: M90 flow?
    Charles City, IA
    According to the figures posted in this thread I get roughly 22ci per rev at 14k.
  11. #31 Re: M90 flow?
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    By extrapolating the M90 5th gen map, its flowing just over 1200m^3/hr at 14000 RPM and 10 PSI (pr=1.47).
    Since you want CI/RPM of the SC, its easy to convert.
    Intake and exhaust mods allow you to increase mass flow rate through the engine. Also, they reduce supercharger losses.
  12. #32 Re: M90 flow?
    No psi has nothing to do with YOUR question, you asked How much does an M90 flow at 14,000 rpm in ci/rev?
    You said nothing about engine size, Im assuming on a 3.8L engine but it will for sure be less psi on say a 5.7L
  13. #33 Re: M90 flow?
    Banned
    CT
    You're thinking! Perfect!
    But 22ci/rev is not the right answer.
    But it's not 90 either!
  14. #34 Re: M90 flow?
    Banned
    CT
    And the flow would be different. Wanna give it a shot? Other people are stepping up!
  15. #35 Re: M90 flow?
    Dec 2010
    Canada
    Why dont you just play with the units? I gave you the answer.
  16. #36 Re: M90 flow?
    Banned
    CT
    Quote Originally Posted by mechguy View Post
    I know the answer. I want people to actually think for themselves rather than read and regurgitate. Have you seen how many people tried telling me it's 90 ci/rev?
    My goal is to enlighten.
  17. #37 Re: M90 flow?
    Waukesha, WI
    hmm so it would be 90ci/rev....in a perfect toleranced blower.
    no two car/motor/blowers are alike, do you want a cookie now?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  18. #38 Re: M90 flow?
    Dec 2010
    Canada
    It would be 90CI/rev if it wasnt producing boost, vacuum was negligable, and if air was perfectly awesome.
  19. #39 Re: M90 flow?
    Dec 2010
    Canada
    I know the answer.
    I do too.
  20. #40 Re: M90 flow?
    Banned
    CT
    Quote Originally Posted by redlinepontiac View Post
    No, this is wrong also. This isn't some sort of trick question with a stupid answer. The number isn't even close to 90ci and has nothing to do with tolerances between blowers.
  1. Is this a Hi-Flow Cat?
    By T0pwater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2011, 08:00 AM
  2. coolant flow
    By sdenton8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2010, 10:54 PM
  3. TDC flow
    Last Post: 05-16-2009, 10:52 PM
  4. Intercooler Flow???
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 08:45 PM
