Thread: coolant flow
Results 1 to 10 of 10
  1. #1 coolant flow
    GT Level Member sdenton8's Avatar
    marshalltown, iowa
    When changing the lower intake manifold and supercharger is it worth to block off the coolant flow thru the supercharger?
    I know if those two holes are blocked off that the side port has to be opened up for better flow to the rear head.
  2. #2 Re: coolant flow
    its nice to not have coolant in the throttle body, but the gains are fairly non existent.
  3. #3 Re: coolant flow
    Charles City, IA
    I left mine open to help in the winter when I drive and its -20 out.
    SMGPFC Two Nipple General
  4. #4 Re: coolant flow
    marshalltown, iowa
    Ok thanks guys and I mite just leave them open then. What about opening up the side port with the top two ports open? It does get cold here in Iowa and I heard about the throttlebody plate getting frozen without the coolant thru it.
    Ok my other question is is it worth taken the egr out or would it mess up my engine? I know the intake would be cleaner and cooler. But doesnt it give you problems cuz the exhaust gas takes up some room in the cabustion chamber and helps with gas mileage.
  5. #5 Re: coolant flow
    the EGR is only active when youre cruising and you might only lose a couple of MPG or so at the most.
  6. #6 Re: coolant flow
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    On a driver i would not mess with it.
    My EX wifes other car is a broom.
  7. #7 Re: coolant flow
    marshalltown, iowa
    Yea I'll just have to think about that whole thing then. Ok what about opening up the side port on the lower intake manifold for coolant flow?
  8. #8 Re: coolant flow
    if you block the coolant ports in the LIM then open up the side passage more. what else is there to know?
  9. #9 Re: coolant flow
    Charles City, IA
    You can still open it up with the coolant ports unblocked for better flow.
  10. #10 Re: coolant flow
    marshalltown, iowa
    Ok thats all I needed to know then.
  1. Throttle Body Spacer/Coolant Flow
    By TeeWX in forum General Tech Discussion
    Last Post: 03-26-2010, 12:38 PM
  2. Low Air Flow on Heat HVAC
    By scootcoupe91 in forum General Tech Discussion
    Last Post: 12-12-2009, 06:41 PM
  3. TDC flow
    Last Post: 05-16-2009, 10:52 PM
  4. Intercooler Flow???
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 08:45 PM
