Thanks for the reply. I hope that it is not the wire. I already bought the part thinking that if the obd code shows the sensor is bad then that is what would be wrong. After I ordered it I also found out that there was a recall on the wiring harness. It says that the harness had faults 4-5 inches in from the sensor because it WAS NOT ATTACHED as you said. Two questions, if it shows wear marks where it was towed is the driver responsible? If it is cracked like the recall says would they still grant the recall? Thanks again for the help. Greg
