Thread: Need help with a no code
Results 1 to 14 of 14
  1. #1 Re: Need help with a no code
    Donating Users timboku's Avatar
    Montgomery, IL
    ^^^X2 on the MAF sensor. Cleaning doesnt do anything really. Unplug it and if it runs better thats what it is. i am betting that is the problem. Common issue.
  2. #2 Re: Need help with a no code
    Being an 03 does this still have a fuel pump speed resistor guys? It's not exhibiting quite the correct signs. But the testing is free and easy.
    Check the ICM connector to ensure it's clean and snug on the ICM. Pretend I didn't find that one out the hard way
    Remove and look at both battery cables for corrosion. While the W bodies don't seem to suffer as much from it, the H's with more electronics will stall etc randomly with loose/corroded etc cables.
  1. TFP code
    By NightriderGT2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-21-2011, 05:53 AM
  2. Code 172
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2011, 05:28 PM
  3. does anyone know how to fix this code?
    By shsfootball57 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2011, 12:33 PM
  4. another SES code...
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 10:27 PM
  5. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
