Thread: Won't start after cam install
Page 7 of 23 FirstFirst ... 5678917 ... LastLast
Results 121 to 140 of 448
  1. #121 Re: Won't start after cam install
    Delaware, OH
    Honestly you may as well replace the crank sensor while you have everything apart again.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  2. #122 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I pulled it all apart. My timing marks are correct. Here is a picture:
    I went to turn my crank with the bolt with the front cover off and it turns wayyyy easier now. Should throw it back together?
  3. #123 Re: Won't start after cam install
    how hard did you pound the balancer back on there? did you end up binding anything?
  4. #124 Re: Won't start after cam install
    Bill told me to just use an impact and crank it down. It would have been close to the torque setting though. I'm not sure what was causing it to turn so slowly, and rough. It's night and day from how it's turning now though.
  5. #125 Re: Won't start after cam install
    no dont get me wrong, i did the same thing since the torque spec on the bolt is crazy high unnecessarily.
  6. #126 Re: Won't start after cam install
    Dare I say, pull the oil pump cover off.
    Also, does it look like the chain was rubbing the pump cover?
  7. #127 Re: Won't start after cam install
    I never took the pump apart originally.
  8. #128 Re: Won't start after cam install
    Balancer pictures:
    It looks fine to me?
  9. #129 Re: Won't start after cam install
    did you use heat to get it off? if not you may want to toss it back on, at least the key ways intact.
    if you did use heat, did you see smoke or smell rubber burning? if so you may want to get another balancer.
  10. #130 Re: Won't start after cam install
    I didn't use heat on the balancer. However, something is f*cked up...
    I looked at my balancer, and I see 2 key slots. There is a large one, and then there is a small tapered key slot. I looked at the crank and I only see a small tapered key, at the back of the shaft. Here's a picture of what I mean:
    Did something break?
  11. #131 Re: Won't start after cam install
    The key doesn't come all the way to the front of the shaft, and it looks as though it carved a new slot in my balancer pulley. I can't even get the harmonic balancer on the shaft. It won't go, unless I force it with the crank bolt. What can I do?
  12. #132 Re: Won't start after cam install
    Grand Rapids, MI
    my wild stab in the dark is to try a new balancer..
    but wait a little bit, i'm sure one of the more experienced users will be on shortly
  13. #133 Re: Won't start after cam install
    You might have pushed the key back into the engine and had the balancer on wrong.
  14. #134 Re: Won't start after cam install
    Sooo, is it fixable? What do I need to do?
  15. #135 Re: Won't start after cam install
    as per the key, not sure.
    never had the pleasure of replacing that.
    One came with my new balancer, but i left the old one on there.
    Also unsure if thats the correct position.
  16. #136 Re: Won't start after cam install
    Do you still have your new key?
  17. #137 Re: Won't start after cam install
    probably.
    want it?
    You pay postage.
  18. #138 Re: Won't start after cam install
    probably.
    want it?
    You pay postage.
    Ya I probably will. Unless the balancer I buy comes with it.
  19. #139 Re: Won't start after cam install
    If you buy locally and its a dorman, it'll prolly come with a new key.
  20. #140 Re: Won't start after cam install
    Anyone know what to do about the key? Does the front cover have to come off again?
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
