Thread: 2000 gtp wont start
Results 1 to 13 of 13
  1. #1 Re: 2000 gtp wont start
    GT Level Member uNda6gT's Avatar
    Jan 2009
    Baltimore
    I dont know what other options to check for,seems like it really wants to start but just wont
    02 Pontiac Grand Prix GT:Intake,SLP Powerflo Catback,HV3,DHP PCM, 15.3 @89mph
    96 z28 Geared Stalled Bolt On......Typical
  2. #2 Re: 2000 gtp wont start
    You are going to have one of two problems.
    No spark or no fuel. You said you had fuel at the rail, and spark. Does the fuel spew out when you press the schrader on it? Or do you have a pressure tester to check the pressure?
    Our cars will start on around 26psi or more pressure (don't ask..lol), spark is spark.
    Kinda sounds like you have fuel at the rail and your injector fuse might be bad. (Again..no need to ask)
  3. #3 Re: 2000 gtp wont start
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Where is the injector fuse located?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  4. #4 Re: 2000 gtp wont start
    In the fuse box.
    Other than that..I got a Regal.
  1. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  2. 2000 gtp wont stay running after start??
    By handymontana in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2010, 06:42 AM
  3. 2000 gtp fuel pump wont run after start up
    By look out in forum General Tech Discussion
    Last Post: 05-16-2010, 05:47 PM
  4. Wont start
    By EmEaston24 in forum General Tech Discussion
    Last Post: 08-27-2009, 09:20 AM
  5. car wont start right away .
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 02-15-2009, 01:40 PM
