Thread: 2000 gtp wont stay running after start??
Results 1 to 7 of 7
  1. #1 2000 gtp wont stay running after start??
    Canada
    Hi guys,
    Ok the car is supercharged 3.8 and will start initially and run for 5 seconds then shut right off???
    Can anyone suggest anything to look at? I quickly checked for the fuel pump running and it seems to prime when key is forward .....any help please
    Thanks,
  2. #2 Re: 2000 gtp wont stay running after start??
    What does the security light do when you try to start it? Can you verify the fuel pump is running after it starts?
  3. #3 Re: 2000 gtp wont stay running after start??
    Canada
    The security light is off , it primes when the key is in the on position , when it starts revs fine for 5 to 10 seconds......then shuts off
    To check for the pump running while vehicle is on ? How can I do that after its started with a pressure gauge? ? Could it be a relay ?
    I appreciate your help !
  4. #4 Re: 2000 gtp wont stay running after start??
    Pull the fuel pump spd ctrl relay and bend either pin 85 or 86 off to the side. (this bypasses the fuel pump resistor). If the car stays running, it's your resistor. You can run the pump at full power w/o an issue. But the resistor is expected to be there to keep from overworking the pump.
  5. #5 Re: 2000 gtp wont stay running after start??
    Canada
    Thanks ill try the bypass tonight after work then give you an update ...if this works do I leave it like that or can I replace the relay with a new one to fix it properly?
    Thanks again!
  6. #6 Re: 2000 gtp wont stay running after start??
    Canada
    hey it worked!!!!!!! thanks a million!!! now can i just buy a new relay to fix the issue or do i just leave it?
  7. #7 Re: 2000 gtp wont stay running after start??
    Feb 2009
    flintnasty MI
    get a resistor from a junkyard, or just not worry about it.
    It technically makes your pump wear out faster.
  1. 00 Grand Prix Won't stay running/start
    By bankai in forum General Tech Discussion
    Last Post: 10-10-2011, 11:37 PM
  2. need help car wont stay running
    By ALACEY in forum Introductions/Noob Questions
    Last Post: 07-03-2010, 11:58 PM
  3. Car wont stay running *HELP!!!
    By silverPGP in forum General Tech Discussion
    Last Post: 06-06-2010, 02:46 PM
  4. 2000 gtp fuel pump wont run after start up
    By look out in forum General Tech Discussion
    Last Post: 05-16-2010, 05:47 PM
  5. car wont stay running
    By 98gpgtp in forum General Tech Discussion
    Last Post: 04-17-2010, 07:41 AM
