Thread: erratic running L67
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: erratic running L67
    california
    does it matter that the code reader isn't through a crank learn code? i guess my scan tool doesn't have a crank relearn feature, it's just a actron pocket scan, i can't drive the vehicle on the street either...ugh
  2. #22 Re: erratic running L67
    california
    jim sent me this: where did you tie in the large Pink ignition wire and the Red, battery hot to fuse panel...I want to be sure the system in connected to enough source so when system needs amps/current it will have it.Also do you know any history of the actual fuel injectors? Also ohm them to be sure they are electricly good as that design can be a problem..12 to 18 ohms is good.Also, on a scan tool make sure TPS value is checked in and ramps up as throttle opens..jim
    i have to go to f-ing jury duty now, but i'll be checking all that asap
  3. #23 Re: erratic running L67
    california
    Is there any possibility this could have anything to do with my trans, th350, stock. My buddy keeps thinking it could do with the torque converter but I'm convinced that if the motor was making power and torque and the tranny was bad that it would just smole the trans.
  1. erratic speedo/shifting
    By macey43 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-20-2011, 04:44 PM
  2. erratic spedometer
    By macey43 in forum Audio, Security & Visual Electronics
    Last Post: 01-04-2011, 05:09 PM
  3. Erratic Idle Help me Narrow Down Please
    By 02GTGP in forum General Tech Discussion
    Last Post: 10-16-2010, 01:25 PM
  4. Erratic Temperature Gauge..HELP PLEASE!
    By gtpgrl2000 in forum General Tech Discussion
    Last Post: 08-12-2010, 05:50 PM
  5. Erratic Boost and other odd behavior
    By tpboyce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2010, 09:54 PM
