Thread: pcm from a gt help
Results 1 to 10 of 10
  1. #1 pcm from a gt help
    SE Level Member xBlacKxGTPx's Avatar
    springdale ar
    i have a 2004 pontiac grand prix gtp that recently had a pcm that crapped on me i have hp tuners and i found a couple pretty close that i hope i would be able to use. i was informed that i would be able to use a gt pcm so any assitance would be helpfull not only to me but others along the way. what would be the best process of doin this?
  2. #2 Re: pcm from a gt help
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Should work fine. I flashed 05GTP PCM info into my 04 n/a after swapping the 05 S/C engine, trans, cradle and all into my 04 n/a car. I used my 04 PCM (keep the same VIN) and flashed the new engine info. Worked like a charm. No prob. I have a DHP not a HP Tuner. I am new to Tuning but if you need anything give me a shout.
    Lambokit to be built!!!!!
  3. #3 Re: pcm from a gt help
    springdale ar
    thanks for the clarification on this subjuct so all i need to do is reflash the pcm with the gtp tables and it will work fine.
    i will keep this posted as it progresses tha way if anyone has question tey can refer to this thread
  4. #4 Re: pcm from a gt help
    Florida
    i have heard that some "bricked" pcms can come back to life! after being out of the car for a month or so some people have been able to get them to work again. prob something with the power being completely drained and allowing a good reboot of it... just an FYI not to just toss your old PCM let it get some dust on it and give it a try down the road. and or down the road get or build an off board. sometimes you can flash a pcm on an off board that wouldnt work while in the car because of other bus traffic going on.
  5. #5 Re: pcm from a gt help
    springdale ar
    ok heres my deal with with this i found out that my pcm was not sealed and it leaked water and corroded some diods or what ever it has in it and i have to get another one i just had my trans replaced an now i have to get another pcm so i can once again drive my car. thats my whole reason of asking this question. so now i have to experiment with it and see what i can do. tomarrow when i get back im going to plug it up to the car write a calibration with hp tuners and go from there maybe reconnect vats and see where i go from there. i have a good tune saved already just not 100% sure about the trans tune but i guess ill play with it and see what works for me i have ahd alot of help and advice from some awsome ppl but i have to learn this by my self or i will never learn it. and if it has been off the car for months could i go to the dealer and have them flash it for me to "bring it back to life" or should i be able to do this with just hp tuners?
  6. #6 Re: pcm from a gt help
    Apr 2009
    Radford, Virginia
    Should be able to do it with your HP Tuner.
  7. #7 Re: pcm from a gt help
    Florida
    deff just use your tuner no reason to pay the dealer to try it when you can do it for free. for what they would charge you might be able to find another pcm at a junkyard!
  8. #8 Re: pcm from a gt help
    springdale ar
    once agian thanks guys ill try it tomarrow and see what happens from there
  9. #9 Re: pcm from a gt help
    springdale ar
    well i found out that a "write enitre" is required to be able to use the pcm from a different type of grand prix. its working good and i have had no problems. so just to recap. on the menu bar go to flash click write entire wait about 5 minutes and start it up.
  10. #10 Re: pcm from a gt help
    Donating Users DOHCZ34's Avatar
    Traveling
    Quote Originally Posted by xBlacKxGTPx View Post
    you're on the right track
    Traveling Tuning Authority
pcm
