I got it turned over cranked it a few times my batt died i got it charging while im at work i will go home and make sure i can crank it and get my oil pressure up any issues i should expect like the pump leaked down my oil so i need to re prime i put a quart on the valves and filled the oil filter got plugs out and icm unhooked fuel pump relays out as well anything i should look for??? this is a salvage motor that has sat for a year so im just curious
