Thread: 06 L32 to 99 regal gs starter issue
Results 1 to 6 of 6
  1. #1 06 L32 to 99 regal gs starter issue
    Apr 2011
    cedar rapids,ia
    I did an engine swap into my 99 regal gs with the motor out of a 06 pontiac grand prix gt. My issue is that after i got the engine in and went to start it it just clicked i checked voltage tapped on it and charged the battery but it has the starter off of the 99 regal. my question is if there is a differnce in starter motors or not if so does any one have a part number for me. I could relay use any help i can get on this on the internet isnt telling me much
  2. #2 Re: 06 L32 to 99 regal gs starter issue
    the starter off either should work for you. If you are only getting a click. Ensure that you have all three grounds hooked up at the lower front trans bolt/stud and that the battery cable plus..uh one or two power wires are hooked up at the starter.
    With all of that good, the only other issues/problems could be corroded battery cables or weak battery.
    If you get a click..you can get a vrooom
  3. #3 Re: 06 L32 to 99 regal gs starter issue
    Apr 2011
    cedar rapids,ia
    I found the issue wire un hooked rookie mistake on my part I had it tucked out of the way too well but I gave my l32 scrap yard motor life tonight so all is well I have lots of pics thinking about doing a right up
  4. #4 Re: 06 L32 to 99 regal gs starter issue
    utah
    dont think, do
  5. #5 Re: 06 L32 to 99 regal gs starter issue
    There are never too many write ups.
    A pro leaves stuff out because he takes certain things for granted.
    A newbie details all the steps and shows some stuff as pain points, then the pro's mention the easy way to deal with the issue. Overall you get a great writeup
  6. #6 Re: 06 L32 to 99 regal gs starter issue
    Apr 2011
    cedar rapids,ia
    I got it turned over cranked it a few times my batt died i got it charging while im at work i will go home and make sure i can crank it and get my oil pressure up any issues i should expect like the pump leaked down my oil so i need to re prime i put a quart on the valves and filled the oil filter got plugs out and icm unhooked fuel pump relays out as well anything i should look for??? this is a salvage motor that has sat for a year so im just curious
  1. HELP Starter?
    By JoshsGTP in forum General Tech Discussion
    Last Post: 12-26-2010, 10:04 PM
  2. Car wont start... starter issue
    By Piggy in forum General Tech Discussion
    Last Post: 10-08-2010, 05:17 AM
  3. Need help with a starter...
    By kcbuckeye2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 12:14 PM
  4. 98 Regal GS Lockup + 1-2 Shift Issue -- Repost
    By KFCOrBust in forum General Tech Discussion
    Last Post: 03-22-2010, 02:29 PM
  5. 98 Regal GS Lockup + 1-2 Shift Issue
    By KFCOrBust in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-21-2010, 05:05 PM
