Thread: Full boost but no power
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #1 Re: Full boost but no power
    SE Level Member 98RegalGS's Avatar
    Victorville, CA
    Back fire from under car? Check the plug wires to see if you put them in the right order. Also check the plugs to see if one is cracked. I know the rear plugs are a pain to get in. Good luck
    98 Regal Gs L67 SC. 3.4 Pulley, SLP CAI, 3" downpipe with no u-bend, resonator delete, TB spacer, TB heat shield, 17" Caddy CTS wheels.
  2. #2 Re: Full boost but no power
    GT Level Member jdmgtp's Avatar
    MI
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  3. #3 Re: Full boost but no power
    GT Level Member Deviq's Avatar
    SE WI
    Still trying stuff so now I disco'd the harness to the bcs. Car isn't bogging at all and runs better. I'm assuming this cuts off boost though since I don't have full power but bogging is gone. Any have any ideas?
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  4. #4 Re: Full boost but no power
    SE WI
    Figured I'd update everyone. I was still testing and trying different parts when I got to the tps. Went to pick up a tps from Dan in Sheboygan but needed gas before I left. This was the same ****in full tank of gas from right before swapping out the clogged cat. I noticed water at the filler neck before I filled up and started wondering.. Only put 20 in and tested it out.. Sure ****, bad tank of gas. Everything is working fine and had full power back. My regular station had run out of 93 so I filled up at one down the street. I'm guessing he was low also and I caught the bottom of the tank.
    I'm gonna leave it like this for a few fill ups and see how it runs. Hopefully thats all it was so... Thanks everyone for all the help and suggestions. I ended up learning more than I planned but its all good.
  5. #5 Re: Full boost but no power
    wow, bad gas? ive personally never run into this problem.
  1. I have full boost now.
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 10:52 AM
  2. FWI installed!! ...still not getting full boost though...
    By 03GTPLE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2009, 04:20 PM
  3. not getting full boost?
    By Standby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 05:43 PM
  4. HELP Not making full boost
    By 1slowhatch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2009, 01:31 PM
  5. Did the LIM this weekend, not getting full boost, and getting hot... wtf?
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 10:18 AM
