Thread: Cruise control does not work, suggestions??
Results 1 to 10 of 10
  1. #1 Cruise control does not work, suggestions??
    GTX Level Member crbquist's Avatar
    Massachusetts
    My cruise control does not work. It has not worked for a couple yrs, but since I will be driving my car from MA to FL this summer, I want it to work again. I've been told there is still power at the switch, so the problem is elsewhere.. Any ideas???
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #2 Re: Cruise control does not work, suggestions??
    Waukesha, WI
    3rd break light out?
    fuse?
    cables connected?
    mine stopped working, 3rd break light went out. replaced light and works again
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: Cruise control does not work, suggestions??
    Indianapolis
    Is your airbag light on and does your horn not work?
  4. #4 Re: Cruise control does not work, suggestions??
    Houston
    Mine stopped working the same time my abs and trac off lights came on....it was the ABS module.
  5. #5 Re: Cruise control does not work, suggestions??
    Massachusetts
    Nope, everything else works (except for the heated seat) Could it be the module?
  6. #6 Re: Cruise control does not work, suggestions??
    Houston
    Cruise module maybe, but if your abs light and trac light isnt on then its not gonna be the Abs module.
  7. #7 Re: Cruise control does not work, suggestions??
    Jul 2010
    Houston, Texas, United States
    Check all fuses first,then answer this....Do you have any external led bulbs on the car?
    I only ask cause I know that if you do sometimes it screws up your cruise control. Always start small and cheap bro.
    My .02
  8. #8 Re: Cruise control does not work, suggestions??
    HUDSON
    The third brake light thing is wierd to me, how are these too realted?
    To put in comparison, it's like saying the cieling fan in my bedroom will not work unless I tell the misses she looks smokin hot before turning in for the night.
  9. #9 Re: Cruise control does not work, suggestions??
    Waukesha, WI
    i know its goofy but its how our cars are,
    you tap the brakes to cancel cruise, if you third light is out. your cruise wont work. i LOVE GMs lol.
    RayRay
    92 Turbo miata
    02 lexus is300
  10. #10 Re: Cruise control does not work, suggestions??
    Out West
    brake switch.
  1. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  2. Cruise Control Help !!!
    By avenger33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2010, 07:33 PM
  3. 2006 GPGT, cruise control doesn't work.
    By acammer in forum General Tech Discussion
    Last Post: 11-23-2010, 07:56 AM
  4. Cruise Control
    By TeeWX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2010, 07:16 PM
  5. Cruise control and AC won't work
    By ala17 in forum General Tech Discussion
    Last Post: 06-28-2009, 11:47 PM
