Thread: 2000 grand prix GTP Temp gauge
Results 1 to 13 of 13
  1. #1 2000 grand prix GTP Temp gauge
    Apr 2011
    canada
    hello i have a 2000 gtp and my temp gauge jumps alot it jumps up and down from 70 to just over 100. any ideas on the prolem. Thanks a million
  2. #2 Re: 2000 grand prix GTP Temp gauge
    Texas
    Lets go with the simplest most possible reasons;
    1. Is your car stock? Or modded? What kind of mods?
    2. Does this happen when driving highway and when in moderate to heavy traffic? It is normal for your needle to jump up a bit when you are in traffic and to go down when you're on the highway free of traffic. Though 70 to 100 is extremely cold and you're running extremely rich.
    3. Have you tried bleeding out the air of the system?
    4. What kind of thermostat do you have? If you don't know, you should probably change that out first.
    5. Is your coolant level correct? Check if it's dirty with mud like crap on the radiator cap. Is your radiator full of just water or just coolant and not 50/50 mixed? (make sure the car is cool of course before doing this)
    6. Other than that, are the fans kicking in at the right time and are they both working?
    EDITED TO INCLUDE Bio248s suggestion.
  3. #3 Re: 2000 grand prix GTP Temp gauge
    sounds like air in the system. otherwise the needle shouldnt move that much that quickly.
    however, your numbering is way off, 70 and 100 are super super super super super super cold.
  4. #4 Re: 2000 grand prix GTP Temp gauge
    Texas
    That's right how could I forget. Maybe you need to bleed out the air. Now if nothing but coolant comes out then start with what I mentioned. If you need help say so.
    And yes, 70 and 100 is way too cold. Perhaps he don't even have a thermostat or a 160 with stock car.
  5. #5 Re: 2000 grand prix GTP Temp gauge
    Apr 2011
    Elk Rapids, Michigan
    70-100 are pretty normal in a Canada car.....metric.....70 C = 158 F and 100 C = 212 F.
  6. #6 Re: 2000 grand prix GTP Temp gauge
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Quote Originally Posted by ExLimey View Post
    Bouncing from 210 ish to 160 ish is normal.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  7. #7 Re: 2000 grand prix GTP Temp gauge
    Quote Originally Posted by EJOUIE View Post
    no, going from 180-210 slowly is normal. Considering traffic or open roads. once moving temp should be a steady 180-195*, then in traffice it should rise slow and settle around 210* where then the fans kick on at 212-216ish.
  8. #8 Re: 2000 grand prix GTP Temp gauge
    Newnan, GA
    then I guess mine needs to be checked then. lol.
  9. #9 Re: 2000 grand prix GTP Temp gauge
    Apr 2011
    I wasn't trying to imply that bouncing from 160 to 212 is normal, just that the temps are not as cold as people thought. I do agree that it is far from normal operation.
  10. #10 Re: 2000 grand prix GTP Temp gauge
    Newnan, GA
    what I meant by bouncing was that it would never be still. It would move up to 210 then back down to 160 and then back up. I was also considering that stops and typical traffic with that.
  11. #11 Re: 2000 grand prix GTP Temp gauge
    Apr 2011
    canada
    Thanks to everyone for all the imput, now I did a colant flush I canged the tstat and I bled the line but the temp gauge is still jumping around it goes a couple clicks past 100 degres celceus and I noticed my fans dident come on and I know they work because of the heat and a.c so I wemt and got a colemt temp switch and I put it in and the gauge in the car was off the chart almost like it wasent grounded any ideas guys??
  12. #12 Re: 2000 grand prix GTP Temp gauge
    Texas
    Do you have Autozone or something similar where you live where they offer free OBD II scans? Only thing I can think of is an electrical issue because if your fans aren't turning on at the correct temperature then that's pretty much your problem.
    I would say take it to get scanned or have a mechanic take a look at it, in the meanwhile continue to try and bleed the air because sometimes you don't get it all the first time.
  13. #13 Re: 2000 grand prix GTP Temp gauge
    Apr 2011
    canada
    i have an OBDII tool and its not reading any codes i went and got a new colent temp switch and im going to try the new one, im wondering if the switch is different for S.C and Non S.C eather way i got a new one and am going to try that.
  1. 04 grand prix gt temp gauge problem
    By Filion in forum General Tech Discussion
    Last Post: 01-26-2011, 05:22 PM
  2. 2000 Grand Prix GT Fuel Gauge
    By Hozer1980 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2011, 06:32 PM
  3. 2005 Grand Prix - temp gauge/cooling fan issues.
    By lateralus20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2011, 12:46 AM
  4. 2000 Grand Prix Fuel Gauge
    By Hozer1980 in forum Off Topic Discussion
    Last Post: 03-21-2010, 07:12 PM
