Thread: the codes my car is throwin
Results 1 to 9 of 9
  1. #1 the codes my car is throwin
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    alright kids my ses light turned off the other day finally up to 440 miles on the rebuilt engine but had a gut feelin i should scan it so i went to auto zone got the scanner and it came up with these with the ses light still off
    p1361 not to sure what that is but i also go p0107 which im pretty sure is the vacuum leak correct anyways ya
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  2. #2 Re: the codes my car is throwin
    St. Louis
    code P1361 Ing. Control Circuit Low Voltage
  3. #3 Re: the codes my car is throwin
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Really, is it hard to look up the codes and post what they are? ignition control circuit low voltage Sounds like a kinked wire P0107 trouble code which refers to Manifold Absolute Pressure/Barometric Pressure Circuit Low Input Id say theres a harness issue as im pretty sure there bundled together. Non of those are indictive of a vacuum leak. Check the Harness
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: the codes my car is throwin
    no my pen wasnt workin so i just wrote what the numbers were but the car every once in awhile has rough idle and dies at idle so i was thinkin vacuum leak of some sort
    SMGPFC #77
  5. #5 Re: the codes my car is throwin
    and where would the ignition control circuit be
    SMGPFC #77
  6. #6 Re: the codes my car is throwin
    Hagerstown,Md
    it goes to the ICM and or the CPS Your gonna need a Wire Schmatic(Sp)
  7. #7 Re: the codes my car is throwin
    ah ok thanks
    SMGPFC #77
  8. #8 Re: the codes my car is throwin
    now when it came up with the p0107 it said misfire and i do know this for a fact that im getting gas mixed with in the oil because my rings havent set
    SMGPFC #77
  9. #9 Re: the codes my car is throwin
    illinois
    My car is throwing a P0107 code and it indicates either MAF vacuum leak or 22 sensor...not sure which one it is, but never said anything about an manifold absolute pressure. What that about and would it mess with the rpms @idle?
  1. Codes
    By 04PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2011, 07:02 AM
  2. Throwin some codes
    By SDGTP99 in forum General Tech Discussion
    Last Post: 05-22-2010, 01:26 AM
  3. My car is FU**** WTF? 48 Codes
    By Toofastgs in forum General Tech Discussion
    Last Post: 12-24-2009, 10:57 AM
  4. 3 codes, what could it be?
    By spidamanSS in forum General Tech Discussion
    Last Post: 08-19-2008, 02:24 AM
  5. I got some codes
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2008, 07:41 AM
