You'll probably need larger injectors with a 3.0. Scan your IPW first, I believe the max you'll get is around 19.5 at 6k rpm. If you're near 19, then yes you need injectors for sure.
Have you tried to read/write your .bin with HP tuner? You can get the injector tables scaled very easily with a tuner.
