Thread: wat do i need to do
Results 1 to 16 of 16
  1. #1 wat do i need to do
    GT Level Member lilrocket's Avatar
    landis,nc
    ok i have a dhp pcm and i just found my 42lb injectors wat do i need to do to put them in as fare as my tune goes im at a speed bump here, do i put the in and go or do i have to send my pcm off again
    98 DAYTONA 1110/1500: work in progress
    00 DAYTONA 216/2000: totaled but not forgotten parts car
    "Speed its my drug, the faster i go, the faster i want to go!"
  2. #2 Re: wat do i need to do
    Unless you can tune...then yes you will. Why do you need 42lb injectors? Are your IPW's maxed?
  3. #3 Re: wat do i need to do
    landis,nc
    mm shouldnt be but they i was told the stockers max out with any pulley under like the 3.2 and im running the 3.2 with no kr now so i wonted to try out the 3.0 this weekend just rather b safe then sorry. any help is grate tell me more
  4. #4 Re: wat do i need to do
    Charles City, IA
    You are in the mod range you should have your own tuner.
    SMGPFC Two Nipple General
  5. #5 Re: wat do i need to do
    landis,nc
    im a cheap bastard lmoa i would like to have hp tuner i just cant brake down to spend that much on one i have a friend who has it thats pretty cool that could tweak it for me i just wasn't 100% sure i needed to
  6. #6 Re: wat do i need to do
    Charles City, IA
    You 100% need to scale the injector tables for the 42s and he cant rewrite a dhp pcm with out starting from scratch.
  7. #7 Re: wat do i need to do
    landis,nc
    so i was told by john with intense damnn guess ill just order a intense pcm anyway im not sure if i need the injectors in or not but i just know everyone says you cant runa 3.0 or watever with stock injectors idk my cars weird runs strong as hell but the mods i have count i guess
  8. #8 Re: wat do i need to do
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    you should also get a pump rewire. no Knock doesnt always mean your cars running good or well. You can run what ever pulley you want. But when a piston objects the money you saved on mods kinda becomes mute. Also when your at the track running low 14's on a 3.0 pulley. It kinda becomes Mute aswell
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  9. #9 Re: wat do i need to do
    landis,nc
    i have that (Venturi Specific Walbro Fuel Pump w/harness, via INTENSE) im waiting to the week end to c how it runs then i have a couple new pics and mod list to post up blow some minds as fare as money spend power gained
  10. #10 Re: wat do i need to do
    Hagerstown,Md
    Like I said, Just because you have no Knock that really doesnt mean you should or could run a smaller pulley. What valvetrain mods or intercooler do you have. Whats your AFR? whats your Timing wot?
  11. #11 Re: wat do i need to do
    landis,nc
    mmmm secret valvetrain mods they experimental AFR is around 11.7 the last time i checked it with wide band, which i guess will go back on since my bike needs it no more, timing at wot i have no clue let you know by the week end just ordered the aerofroce gauge
  12. #12 Re: wat do i need to do
    Hagerstown,Md
    well then how do you know theres no KR if you have no way to scan?
  13. #13 Re: wat do i need to do
    landis,nc
    my buddy has HP TUNER and we scan it every week end when we go out playing around slaying zs, and hondas
  14. #14 Re: wat do i need to do
    Charles City, IA
    So you dont look at timing while scanning?
  15. #15 Re: wat do i need to do
    Or anything else besides knock?
    Jeniuz
  16. #16 Re: wat do i need to do
    GTX Level Member Juanmiguel's Avatar
    Mexico
    You'll probably need larger injectors with a 3.0. Scan your IPW first, I believe the max you'll get is around 19.5 at 6k rpm. If you're near 19, then yes you need injectors for sure.
    Have you tried to read/write your .bin with HP tuner? You can get the injector tables scaled very easily with a tuner.
wat
