If I installed some L26 ported and polished heads on my 2001 GT with the SS M90 kit, what kind of pulley drop could I expect? I'll probably do a cam at the same time, but I'd like to know what I could get away with (without the cam).
You already have headers...
Heads/Cam probably/most of the time allow at least a half inch drop in pulley size. Since your high compression a 3.25" or a 3.4" might suffice with more timing...should run great.
ZZP doesnt sell 3.25 pulleys anymore with the SS Kit. Your gonna need to go to a GTP belt/pulley set up to run under a 3.4
I was just curious. I am probably going to sell my heads and just buy a VS cam. I can't afford to get my heads cleaned up and built at a machine shop.
S1X or XP.. don't waste money on VS. How can you pick up a cam that's named Very Small?
People have made power with the VS cam. It's very streetable and I don't have to change any valvetrain components to run it, correct? Plus I can get a VS cam for $230 shipped.
Meh...I'd rather run 90's or 105's with a XP or S1X
I'm sure they are...
VS cam plus 1.7 rockers= Decent
broke college student w/bad transmission + cam = bad.
G8 springs and retainers would be fine on a VS cam and I'd definitely change them if it were my car.
The VS is still a very noticeable difference over stock.
