Thread: Ported & Polished Heads = Pulley Drop?
Results 1 to 18 of 18
  1. #1 Ported & Polished Heads = Pulley Drop?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    If I installed some L26 ported and polished heads on my 2001 GT with the SS M90 kit, what kind of pulley drop could I expect? I'll probably do a cam at the same time, but I'd like to know what I could get away with (without the cam).
  2. #2 Re: Ported & Polished Heads = Pulley Drop?
    You already have headers...
    Heads/Cam probably/most of the time allow at least a half inch drop in pulley size. Since your high compression a 3.25" or a 3.4" might suffice with more timing...should run great.
  3. #3 Re: Ported & Polished Heads = Pulley Drop?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    ZZP doesnt sell 3.25 pulleys anymore with the SS Kit. Your gonna need to go to a GTP belt/pulley set up to run under a 3.4
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Ported & Polished Heads = Pulley Drop?
    You do realize that not dropping pulley and retuning might make more power?
  5. #5 Re: Ported & Polished Heads = Pulley Drop?
    pretty sure it WILL make more power, but who am i to say.
  6. #6 Re: Ported & Polished Heads = Pulley Drop?
    I was just curious. I am probably going to sell my heads and just buy a VS cam. I can't afford to get my heads cleaned up and built at a machine shop.
  7. #7 Re: Ported & Polished Heads = Pulley Drop?
    S1X or XP.. don't waste money on VS. How can you pick up a cam that's named Very Small?
  8. #8 Re: Ported & Polished Heads = Pulley Drop?
    you should to be safe, but you dont HAVE to if youre poor/lazy.
  9. #9 Re: Ported & Polished Heads = Pulley Drop?
    If I wanted to change the springs, I have some new G8 springs I could use. Is that all I would need to change to use an XP or S1X cam?
  10. #10 Re: Ported & Polished Heads = Pulley Drop?
    Meh...I'd rather run 90's or 105's with a XP or S1X
  11. #11 Re: Ported & Polished Heads = Pulley Drop?
    L76 springs aren't good enough?
  12. #12 Re: Ported & Polished Heads = Pulley Drop?
    I'm sure they are...
  13. #13 Re: Ported & Polished Heads = Pulley Drop?
    Hagerstown,Md
    VS cam plus 1.7 rockers= Decent
  14. #14 Re: Ported & Polished Heads = Pulley Drop?
    broke college student w/bad transmission + cam = bad.
  15. #15 Re: Ported & Polished Heads = Pulley Drop?
    Quote Originally Posted by That Canadian Guy View Post
    My transmission is good to go. I found the problem causing the P0716 and P0717 codes. It was just the wiring going into the PCM shorting out in my intake cone.
  16. #16 Re: Ported & Polished Heads = Pulley Drop?
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    G8 springs and retainers would be fine on a VS cam and I'd definitely change them if it were my car.
    The VS is still a very noticeable difference over stock.
    Email all inquiries to willoverkill@gmail.com!
