Thread: TB removal
Results 1 to 20 of 32
  1. #1 TB removal
    New York
    I'd like to clean out my TB and do it right by removing the TB and really getting in there. Does anyone have a write up/link about how to remove the TB? Do I need to disconnect the battery first? Any other important things to know? Thanks.
  2. #2 Re: TB removal
    Charles City, IA
    Unplug the sensors, reomve the throttle cables, then its 3 10mm nuts, you will need a new gasket.
    SMGPFC Two Nipple General
  3. #3 Re: TB removal
    New York
    Thanks, exactly what I was looking for. Oh, d/c battery or doesn't matter?
  4. #4 Re: TB removal
    Apr 2009
    North Jersey
    battery doesnt matter. ive done it many times.
  5. #5 Re: TB removal
    Charles City, IA
    Yeah I would just leave the battery connected
  6. #6 Re: TB removal
    New York
    Thank you both, sorry one last question. I remove the entire throttle body cable assembly or no? Like it's bolted to the TB with 2 10mm or do the cables themselves come off somehow? Sorry I'm a total noob at this kind of thing.
  7. #7 Re: TB removal
    Charles City, IA
    Cables come off, the cruse pushes forward and pops off, the throttle cable as a little dowel on the end, you should be able to see how they come off.
  8. #8 Re: TB removal
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
  9. #9 Re: TB removal
    New York
    Thanks again. My TB is gunk free again!
  10. #10 Re: TB removal
    New York
    Update.
    Car was running great and then all of a sudden today during normal driving the SES light came on. I know it's a real general question but any suggestions about things to check related to my TB cleaning that might have tripped the light before I take it somewhere? Car seems to still be running good and I don't notice any loss of power or mpg.
  11. #11 Re: TB removal
    Nov 2009
    did you disconnect the maf?
  12. #12 Re: TB removal
    New York
    Yes, is that good or bad lol?
  13. #13 Re: TB removal
    Plug it back in?
    Go to your local auto parts store and get the code pulled to see what it is.
  14. #14 Re: TB removal
    New York
    Ah should have clarified, it got plugged back in when the TB went back on. I'm headed out to pepboys in a bit to see what they can tell me.
  15. #15 Re: TB removal
    New York
    Update. Finally took the car to AZ today and they found two codes:
    P0507
    and
    P0305
    the 0305 cylinder 5 misfire I think is just a result of my own stupidity. I took a plug wire off to check it and started the car with it still off. Car only ran for a second before I remembered and shut it off. Is there a way to reset the codes to see if this will clear now that everything is hooked back up?
    The 0305 engine idle too/high low is confusing me. All I did was clean the TB and run a can of seafoam through the gas. The car seems to run great now no surging, not sluggish etc.. Is there a quick fix that I can try to correct this issue? Thanks in advance.
  16. #16 Re: TB removal
    Lansing, Michigan
    Try disconnecting your Battery and leave it diconnected for approx. 5 minutes then reconnect. That should clear the codes.
  17. #17 Re: TB removal
    New York
    Thank you. I'll try that tonight and see if that clears the cylinder 5 code. Anybody able to offer any insight about the idle speed/throttle body issue?
  18. #18 Re: TB removal
    Charles City, IA
    How old are the plugs?
  19. #19 Re: TB removal
    New York
    35k on them. They're the 100k mi variety that came on the car, never changed them.
  20. #20 Re: TB removal
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Here is my thottle body at 134k Miles:
    Before: http://www.flickr.com/photos/60647329@N05/5548208732/
    http://www.flickr.com/photos/60647329@N05/5548208736/
    After: http://www.flickr.com/photos/60647329@N05/5547861575/
    http://www.flickr.com/photos/60647329@N05/5547853485/
    The best I could do with paper towels and Carb/choke cleaner that was ok to use on the TB.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180ยบ Thermostat, Flipped Dog Bones
  1. Ashtray Removal?
    By CSteen85 in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2010, 08:59 AM
  2. Rear Hub Removal
    By trenaro in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2009, 06:18 PM
  3. 98 gtp dash removal
    By mscott9549 in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2009, 08:43 AM
  4. blower removal
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2009, 06:28 PM
  5. Stud removal
    By TheOtherNick in forum How To Write-Ups/Tech Tips
    Last Post: 01-04-2009, 11:21 PM
