Thread: testing for knock
Results 1 to 20 of 28
  1. #1 testing for knock
    St. Cloud, Minnesota
    i need to test my new modded 1997 gtp for knock to see if its actually running this 3.0" sc pulley right.
    not sure whats exactly done but..
    very large cam
    3" exhaust
    headers
    3.0" pulley
    some sort of pcm tune
    valve train to match cam
    larger injectors not sure on # (how can i determine what injectors i have?)
    trying to figure out what has been done and if its going to blow.
    how can i test for kr without spending a fortune. does caspers knock gauge work. I would like to really know numbers tho not just a couple led lights.
    If anyone lives around the st. cloud MN area with a scanner that would be pretty cool but seems far fetched
  2. #2 Re: testing for knock
    Charles City, IA
    Not sure of any local guys with a scanner around ya. I could hit ya up if I am ever up north.
    SMGPFC Two Nipple General
  3. #3 Re: testing for knock
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    that almost sounds like the car chad use to have before he goit his t/a and if it is there is no kr
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  4. #4 Re: testing for knock
    Houston
    Im with ya man, I bought one from the dealership and thought it was stock besides the CAI. Thats not the case. It has been modded. Im wondering how to find out about the internals as well, like cam, rockers, shift kit. How can you tell without ripping it apart?
  5. #5 Re: testing for knock
    you dont.
  6. #6 Re: testing for knock
    Jan 1970
    Maquoketa, Iowa
    mnclubgp.com should have a few people near you with scanners or know the history of the car if it was purchased in mn.
  7. #7 Re: testing for knock
    Upgraded rockers minus modded 1.9's you can tell by taking off the oil cap and looking at them. A cam will idle rougher than stock...even a VS feels like a misfire.
  8. #8 Re: testing for knock
    thanks for the info.
    nascartech...was his car black with tan interior with larger drilled rotors up front? I bought it form a guy in duluth and im not sure who he bought it from but thats who did all the work.
    you can tell right away it has quite a lot of cam lift. I know the pcm has been tuned too cause the fans stay on for a min. or so after you shut off the car
  9. #9 Re: testing for knock
    He didn't tell you what cam was in it?
  10. #10 Re: testing for knock
    take a picture of the injectors.
    get a video of the cold and warm idle.
  11. #11 Re: testing for knock
    ya i have the numbers. its a custom ground cam from comp cams. Intake lift is .556 and exhaust lift is .564. i do have some other numbers too.
  12. #12 Re: testing for knock
    you can type the numbers on the cam card into comp's site and itll tell you what cam it is.
  13. #13 Re: testing for knock
    Charles City, IA
    PRJ cam maybe? I think thats the lift numbers for it.
  14. #14 Re: testing for knock
    ya im not sure he just said it was custom ground from comp cams. Grind # GM38 3314/3315 HR113.0. All i really want to do is get it scanned for knock to make sure everything is good
  15. #15 Re: testing for knock
    Easiest way IMO...and best tool for you is to buy an Aeroforce Scan Gauge.
  16. #16 Re: testing for knock
    ya i cant afford over $200 for it. Im going to be selling it soon just want to know if its knocking or not
  17. #17 Re: testing for knock
    If it has a MPS system...buy a new pulley and toss it on there...like a 3.4"...it won't knock then.
  18. #18 Re: testing for knock
    i do have 2 bigger pulleys a 3.2 and a 3.4 i think. I just going to try and get my uncle to barrow his scan tool from the shop he works at.
  19. #19 Re: testing for knock
    if its got the headers,cam, and bigger injecters than the 3.0 should be fine since you said it had some kind of tune on it... if its nocking its very little...
  20. #20 Re: testing for knock
    Nov 2010
    Marine City MI
    What color are the injectors? Green are 42.5's.
    99 GTP, ZZP MPS 2.9 pulley, GenIII supercharger ported & polished, machined intake W/ stage 2 intercooler, XP Cam,ZZP fuel rails, 42.5 injectors, Wizard CAI, custom headers, 3 inch downpipe, into dynomax muffler,180 stat, Northstar TB, 85mm MAF, ZZP trans, 3.29 gears, input shaft and torque converter, stock heads W/Ls6 springs.
  1. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
