Thread: whats peoples average mpg on 3.4 setup?
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 105
  1. #61 Re: whats peoples average mpg on 3.4 setup?
    Jul 2008
    sumter,south carolina
    maybe ur gas tank is full of cocaine.
    02 GTP with mods 05 GP for DD
  2. #62 Re: whats peoples average mpg on 3.4 setup?
    All city
    19-20mpg
    All high way
    26-28mpg
  3. #63 Re: whats peoples average mpg on 3.4 setup?
    Topeka, KS
    All city
    19-22mpg
    All high way
    26-30mpg
  4. #64 Re: whats peoples average mpg on 3.4 setup?
    Vancouver, WA
    My DIC is usually off by about 7/10's of a gallon per 12 gallons it says I use, in the bad direction. In the winter I'm getting about 14 city and 26 highway, summer 16 city and maybe 30 highway. My mpg dropped quite a bit when I went from stock alloy wheels to heavy 18's.
    Slowest 'Cooled Gen V ever
  5. #65 Re: whats peoples average mpg on 3.4 setup?
    SE Level Member Fierogtfreak's Avatar
    Tri-cities, WA
    Maybe thats part of my problem ive got stupid crome 18's on it....i bought it with them on it and wish i could afford to get different ones...i just got new tire on them soo id have to get another set of 18's
  6. #66 Re: whats peoples average mpg on 3.4 setup?
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    A little off topic from the OP question, but, with everybody noticing such a loss in MPG when switching to larger wheels (as mentioned above), I think I will keep the little 16's on for a while. Stout new BFG tires will help out the looks and traction, and maintain MPG, because my Michelins are dead.
  7. #67 Re: whats peoples average mpg on 3.4 setup?
    I've got 235/55/17 '05+ Bullitts...and they are heavy wheels. You can click the link in my signature for mods...I get anywhere from 28-32 MPG's on the highway constantly...mixed city/highway I'll see about 22-24. In the city...if I'm nice to it...about 15-17...but most of the time about 12-14 in the city...because hammering on it from 40 or under is fun...and just leaves 2 nice black marks
  8. #68 Re: whats peoples average mpg on 3.4 setup?
    Vancouver, WA
    What link goes to your mods? Not either of the two I see. I'm sure the cam doesn't help. Aren't you on 3.29's?
  9. #69 Re: whats peoples average mpg on 3.4 setup?
    Yes 3.29's...and the 1st link goes right to it. I just clicked it to make sure...but just incase...you missed it.
    Bulldog Racing Engines Balanced and Align Bored L67 3800 Series II V6
    ARP Head Studs
    ARP Main Studs
    Clevite77 Main/Cam/Rod Bearings
    Balance Shaft Deleted
    GM '04+ L32 Powdered Connecting Rods
    GM '04+ L32 TTY Rod Bolts
    GM '03 8.5:1 Compression L67 Pistons
    Thrasher Engineered Performance Race Camshaft (.574/.566 114 LSA)
    GM LS7 Lifters
    Comp Cams Rocker Arm Bolts
    Intense-Racing O/R Stock Length Pushrods
    Bulldog Racing Engines Custom Ported/Polished L67 Heads
    Manley #130 Valve Springs
    Manley Titanium Retainers
    GM OEM Valve Guides Milled .100" for cam clearance
    GM '04+ L32 Valves
    Comp Cams Valve Locks
    Viton Valve Seals
    Devil's Own Methanol Injection
    Ported Lower Intake Manifold Inlet/Runners
    Ported Factory GM GenIII M90 Supercharger:
    -Rebuilt using OEM GM Seals/Fluids/Bearings
    -Ported Inlet/Outlet
    -Machined Supercharger Snout
    Custom LS1 Throttle Body Setup/Polished Adapter Plate
    LQ4 MAF Sensor w/ Open Cone Intake Setup
    ZZPerformance Modular Pulley System includes 3.2/3.0/2.8/2.6
    ZZPerformance 160* Thermostat
    Custom HP Tuners Tuned PCM
    Pacesetter Headers:
    -2000* Resistant Armor Coated
    -1 7/8" Primaries - 3" Downpipe
    -Custom Welded 2 Piece Design
    -Catless
    Gene & Calvin's Custom Exhaust Setups
    1) Street Exhaust - 3" Custom Bent, 26" Glasspack/Spintech Universal Race Bullet Muffler with 4" G8 GXP Replica Tips
    2) Offroad Exhaust - 3" Mandrel Bent Piping, 26" Glasspack, No Muffler, Dumped Behind Pass. Rear Tire (In Video)
    MSD Ignition Coil Packs
    MSD Ignition 8.5mm Spark Plug Wires
    Autolite 103 Copper Core Spark Plugs
    Triple Edge Performance Built 4T65E-HD
    3.29 Gears
    Trans-Go Shift Kit
    Full Rebuild with Hardened Clutches/Bands
    Hardened 4th Shaft
    7/8" Single Chain Setup
    Allison TransSend Transmission Fluid
  10. #70 Re: whats peoples average mpg on 3.4 setup?
  11. #71 Re: whats peoples average mpg on 3.4 setup?
    I liked the "whoring" part better...plus...apparently teh guy couldn't click "more" on my youtube video info.
  12. #72 Re: whats peoples average mpg on 3.4 setup?
    Vancouver, WA
    Nope that extra click was just too much for me.
  13. #73 Re: whats peoples average mpg on 3.4 setup?
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    Well this sucks...I just reached half a tank on my gas gauge and have only gone 100 some odd miles...idk what to trust the dic with how much fuel iv used or the tm gas gauge that ppl say are usually off lol any suggestion?
  14. #74 Re: whats peoples average mpg on 3.4 setup?
    Dec 2010
    Canada
    ^ Maybe you drove with one foot on the brake, or some hawt heavies in the back seat?
    But seriously, as been stated, it all depends. Were those 100 miles accumulated making 1/4 mile passes at the local dragstrip?
  15. #75 Re: whats peoples average mpg on 3.4 setup?
    Dec 2010
    Lawrenceville, GA
    I will admit that I do put my foot down at times but not an insane amount but I guess that would make sense plus I dint even think about this but we think my cat is clogged...
  16. #76 Re: whats peoples average mpg on 3.4 setup?
    Dec 2010
    Canada
    ^ Oh yes, if your cat is clogged you will be getting low MPG, and lacking a lot of power. Best to get that fixed soon.
  17. #77 Re: whats peoples average mpg on 3.4 setup?
    If the converter is clogged...beating on a car would be the last thing I'd be doing.
  18. #78 Re: whats peoples average mpg on 3.4 setup?
    Dec 2010
    Lawrenceville, GA
    Only problem iv got is I can't get the darn DP loosened iv been tryin to get a friend of mine use his air compressor and torque reach but things haven't been working out much.but I do all ready have an o2 emulated on it just have to find a way to get the cat off and clogged
  19. #79 Re: whats peoples average mpg on 3.4 setup?
    Put some PB blaster on the DP bolts...if that doesn't help...I recommend some manly armz
  20. #80 Re: whats peoples average mpg on 3.4 setup?
    just break the bolts and put in new ones. that's the easy way to do it.
  1. Post up your Average MPG
    By Whiplash Performance in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2011, 10:46 AM
  2. Average/normal oil pressure
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 02:12 PM
  3. Average cost of going turbo?
    By BwolfGT in forum Turbo
    Last Post: 03-13-2010, 02:41 PM
  4. Turbo. Wheres the best place to get one and whats the best setup.
    By GPdude97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-05-2009, 05:58 PM
  5. Average gas mileage.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2008, 11:49 AM
