Hey I'm just curious what a normal oil pressure should be. I'm anywhere from 60 PSI (idle) to around 90 PSI (WOT).
Thats just fine, 90 is a little high at WOT, but you will be fine. Mine is 50-80.
fully heatsoaked at idle in gear i see as low as 35 psi.
second i touch the gas its up to 60.
Also, what oil are you running?
hmm. kinda high for a 30 weight.
I wouldnt be too concerned though.
What oil pressure gauge do you have?
