Thread: High KR! ?
Results 1 to 20 of 23
  1. #1 High KR! ?
    SE Level Member Hawkman's Avatar
    Jun 2010
    North east, WI
    I have been having high kr issues and cant seem to figure out why or where its coming from mods are as folows fwi, sd headers, al 104s, intence pcm, 3.4 mps, just put a new snout on due to the bearings going bad replaced the coupler at that time as well! i use 93 octane fuel any ideas where to start or ideas whats going on ?
    all stock just as the car was intended!
  2. #2 Re: High KR! ?
    what are you using to monitor KR?
    Have you tried throwing some octane booster in to see if it changes in level?
  3. #3 Re: High KR! ?
    Jun 2010
    North east, WI
    i have a aeroforce intercepter and no i have no tried octane booster i seem to see kr around 7lbs of boost and up and kr is any where from 3 to 7
  4. #4 Re: High KR! ?
    are you running a cat?
    try the octane booster.
    Though you'd probably see KR before that if it was false.
    Still worth a try.
  5. #5 Re: High KR! ?
    Florida
    How cold is it?
    Colder denser air = leaner mix...
    could be why you're knocking....
    Like my car knocked a little when it was below 40...and when in FL, it never knocked.
  6. #6 Re: High KR! ?
    Jun 2010
    North east, WI
    yes i have a cat i replaced it the old one when i put on my headers. i will give the octane booster a try but i dont think its going to help.
  7. #7 Re: High KR! ?
    you could be leaning out and thats causing you to have KR or it could be false.
    But seeing as its only above 7 PSI i'd say you're leaning out.
    Octane booster will help you "get by" for now.
  8. #8 Re: High KR! ?
    Jun 2010
    North east, WI
    its been below zero i have not had warm weather in a while so no whay to verify that if warmer wheater is any different till spring lol
  9. #9 Re: High KR! ?
    Florida
    Quote Originally Posted by Hawkman View Post
    yes i have a cat i replaced it the old one when i put on my headers.....
    do you mean you replaced it WITH the old one, or you replaced it with a new one??
  10. #10 Re: High KR! ?
    Jun 2010
    North east, WI
    i willl have to see what the octance booster does in terms of kr if it takes it down some then at least i will be on a path thanks.
  11. #11 Re: High KR! ?
    Florida
    Ahh, well...again, you will knock like hell if its that damn cold, and you're not tuned for it being that cold.
    Basically when the air is colder, it's denser. So the air density changes, and the fueling doesnt. So you create a lean condition...causing knock.
    One way to test would to be hook up a A/F gauge, and see what she says.
  12. #12 Re: High KR! ?
    Jun 2010
    North east, WI
    i replaced the cat with a new one when i did the header install
  13. #13 Re: High KR! ?
    Jun 2010
    North east, WI
    ok so basically stay out of boost in winter lol
  14. #14 Re: High KR! ?
    yes. i saw a 5 psi increase in boost in the winter. also, your timing is higher due to the lower temperatures.
  15. #15 Re: High KR! ?
    Florida
    Yeah, you boost higher, which = more heat...which = more knock.
    Just stay out of the throttle, or you're gonna go boom.
  16. #16 Re: High KR! ?
    Vancouver, WA
    I'm surprised no one has asked what year your car is yet. If its an 04+ or Gen V equipped your KR doesn't surprise me at all. And some cars just knock more than others. Also you have an intense tune which is known to run the most timing out of all the can tunes which would make it much more likely for you to knock.
    Slowest 'Cooled Gen V ever
  17. #17 Re: High KR! ?
    Bastard Reptile's Avatar
    Kansas City, MO
    Fwiw the car will make some fuel adjustments for the temperature change. I depends on what the IAT sensor sees before the throttle body. This was a reason I tried the modified sensors a few years ago and people thought I was crazy.
    See what your timing is during the knock. Then watch your fuel trims to see how positive or negative they are.
  18. #18 Re: High KR! ?
    octane booster is fun if you use the right stuff
  19. #19 Re: High KR! ?
    Jun 2010
    North east, WI
    Quote Originally Posted by footballplaya3k View Post
    It is a 97 with a Gen III supercharger on it.
  20. #20 Re: High KR! ?
    vac leak?
  1. How high should a L67 be able to rev up...
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2010, 06:49 PM
  2. how high can an L67 rev
    By bowtieguy68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2010, 12:50 AM
  3. High NOX
    By Justin48 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2010, 08:00 AM
  4. How High Is To High?
    By samsquanch in forum General Tech Discussion
    Last Post: 06-17-2009, 12:29 AM
  5. High Flo Cat
    By 04gpking85 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:24 AM
