Thread: pissing coolant!!
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: pissing coolant!!
    Michigain
    Quote Originally Posted by MoBoost View Post
    got the waterpump changed out today. thanks red devil for the ps pump tip!! it was a savior!! lol leave it to gm to make a very easy to change water pump very damn difficult!!
    Glad it worked out for you! Some find it easyer just to pull the p.s pump out of the way. But I find it to work best for my self doing it just the way I explained. Everyone's got there own way and at the end of the job it all works.
    1998 Caged \ Drag GTP = Demoded & Sold
    1999 Caged \ Stattam Turboed GTP hunting for Low 10's
    2008 TrailBlazer SS AWD LS2 400 H.P
  2. #22 Re: pissing coolant!!
    Dec 2010
    Noble, Oklahoma
    Quote Originally Posted by Red Devil View Post
    my friend just did his as well and it took him almost 2 hours to get the bottom bolt re aligned on the ps pump lol. but thanks again
    Boostin To A City Near You
  3. #23 Re: pissing coolant!!
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Glad I could be of some help.
    Your going to most likely smell some coolant for a bit. After an issue like that and then having coolant all over the place it's going to burn off hot part's in the engine bay for a good bit. It's nothing to be to worryed about.
    Most likely reason you heater is still blowing cold is due to their being an air pocket some where in the system. You can go about taking care of this issue one of many way's. Best way to refill a cooling system and be about 100% postive you wont run into an issue is by doing so with this item here. http://http://www.denlorstools.com/h...fill_adap.html
    That's how I do all the system's I open up and it makes it breeze.
    Here is also a link to explain a good way to go about this issue your having as well.
    http://http://www.ehow.com/how_7369_...s-cooling.html
    You may have to do this a few times to get the air pocket worked out of the system.
    Also if you look at the top of the t-stat housing you will see a small bolt in the top of it. Losing that up and crack it open, that is also a good way to get air out of the system as well.
    your links are broken...BTW...I'm still having issues even w/ the new water pump. see here: http://www.grandprixforums.net/new-w...hot-40808.html
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  4. #24 Re: pissing coolant!!
    SE Level Member 1998DaytonaPaceCar's Avatar
    Dec 2010
    Lawton / Fort Sill, OK
    annoying sticking the socket through the pulley hole to a bolt u can't see huh lol
    got mine done last night, no more leaks car stays at about 165-180 now
    1998 Daytona Pace Car #1371 of 1500
    Mods: Pacesetter headers, 3.4" S/C pulley, 180ยบ t-stat, K&N FIPK Intake kit, Cross drilled rotors, 18" rims, DHP PCM, Custom exhaust (Cherry Bomb glasspack acting as resonator, 2X Corsa sport mufflers from my old 06 GTO R.I.P.)
  5. #25 Re: pissing coolant!!
    Dec 2010
    Noble, Oklahoma
    Quote Originally Posted by 1998DaytonaPaceCar View Post
    lol ya it's a pain!!! but now ill drive it and no more coolant smell or anything, but my low coolant light stays on and every once and a while ill see a couple spots of coolant on the ground under the car but it's clean and dry any suggestions?
  6. #26 Re: pissing coolant!!
    Aug 2008
    Long Island, New York
    i just had a bad coolant leak... needed a new water pump and hoses
  7. #27 Re: pissing coolant!!
    Michigain
    For the coolant on the ground, if this becomes an ungoing problem pressure test the cooling system and then go from there.
  8. #28 Re: pissing coolant!!
    east hartford ct
    u can hook up a presser tester to it and presser test it to w ever says on the cap most auto parts store rent them for a depost
  1. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  2. Dogs Pissing On My Wheels !!! WTF !!!
    By DC1263 in forum The Rant Forum
    Last Post: 05-28-2009, 10:27 AM
  3. intense is pissing me off
    By 2000GTP in forum The Rant Forum
    Last Post: 05-18-2009, 09:29 PM
  4. Which coolant to use...
    By Rickochet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 08:34 PM
  5. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
