Thread: Can a bad O2 sensor cause a misfire code?
Results 1 to 18 of 18
  1. #1 Re: Can a bad O2 sensor cause a misfire code?
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    hmmmm well i havent had this car very long maby a few weeks now and we are just trying to settel a few things with it and this seems to be the most anoying...i will give swapping the injectors and run up to advanced and have them read the codes but kinda hoping its not an injector because i dont have money to get one lol i have all ready ordered the O2 sensor cuz we had a theory it could be that plus i ordered the zzp supercharger coupler. but if it were a vac leak where is the most typical place to look for the leak?
  2. #2 Re: Can a bad O2 sensor cause a misfire code?
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    Quote Originally Posted by Spartanzz View Post
    don't know what year the car is but there's a vacuum t under the SC snout that tends to split over time. it's part of a vacuum harness that goes from the bbv, fpr, under the snout over to the map. they're like $15 at the GM store.
    the #3 misfire might be related but it also could be a plug or wire, something like that.
  3. #3 Re: Can a bad O2 sensor cause a misfire code?
    Dec 2010
    Lawrenceville, GA
    Ok so today I went and bought a can of carb cleaner and started spraying and for a hole in the vaccume line right above the sc. I sprayed there and the engine changed rpm. So what I did was repeat the pipe in the hose and tightened the clamp and sprayed it again. It didn't change rpm after that and I sprayed in more places but didn't hear change. I'm not 100% sure if I did it right so how would I know if the leak was fixed? And for the record its a 1997 grand prix gtp
  4. #4 Re: Can a bad O2 sensor cause a misfire code?
    Dec 2010
    Lawrenceville, GA
    Ok guys so i checked the T under the snout and the hose that connected it to the manifold was loose enough to basically pull off with no force so i got a clamp on that and i actually noticed the engine builds boost faster and it seems to have a bit more power. So now im gunna let the car warm up and stand near the exhaust and listen for the puffs of a misfire that i have. Is there any easier way to check for a misfire?
  1. Cylinder 5 misfire trouble code P0305
    By michellebuck76 in forum General Tech Discussion
    Last Post: 04-11-2013, 06:02 PM
  2. Help w/ O2 Sensor code
    By MooseGundr in forum General Tech Discussion
    Last Post: 12-03-2010, 12:18 AM
  3. cylinder misfire code on #4
    By valrathe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2010, 12:14 PM
  4. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
  5. Removing P0300 misfire code side effects....
    By Trannyman95 in forum PCM Tuning
    Last Post: 07-11-2008, 12:29 PM
