Thread: Water Pump
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21 Re: Water Pump
    SE Level Member 1998DaytonaPaceCar's Avatar
    Dec 2010
    Lawton / Fort Sill, OK
    Quote Originally Posted by offroadfury6 View Post
    ummm I didnt need to do any of this. not sure what u broke but I just took the pulley off. are you talking about power steering or idler?
    s/c idler pulley, ps was easy just 2 bolts
    all the other pulleys have bolts for the most part, but the one i need to get off, uh yeah epic fail gm on using t50 torx...
    if anyone knows which way to turn that t50 bolt to unscrew it it would be a great help cause clockwise (reverse thread) apparently was not the answer...
    1998 Daytona Pace Car #1371 of 1500
    Mods: Pacesetter headers, 3.4" S/C pulley, 180º t-stat, K&N FIPK Intake kit, Cross drilled rotors, 18" rims, DHP PCM, Custom exhaust (Cherry Bomb glasspack acting as resonator, 2X Corsa sport mufflers from my old 06 GTO R.I.P.)
  2. #22 Re: Water Pump
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    ummm I believe mine was lefty loosey righty tighty...and no t50 on mine...
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  3. #23 Re: Water Pump
    Dec 2010
    go figure lol wish i had a gen III right about now lol
    any ideas on how to extract, it broke off flush with the bolt
  4. #24 Re: Water Pump
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by 1998DaytonaPaceCar View Post
    ouch buddy ummm I'd say DRILL but it's not that convient down there...I wonder if you take the wheel off and the plastic cover if it would be low enough to get a drill in there...
    other than that i'm clueless...goodluck
  5. #25 Re: Water Pump
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    you can't work on it where it is, as you can see there's no room.
    the only reverse bolt know of is on the assy belt idler.
  6. #26 Re: Water Pump
    Aug 2008
    KCMO
    you can try and use a left handed drill bit. but dont use an easy out. your gunna have to take that bracket off to do this. its gunna be a fun job. and im not talking easy
  7. #27 Re: Water Pump
    Dec 2010
    what about a tap and die set, if i used the smallest one , put a screw in it and pulled on the screw with some pliers?
  8. #28 Re: Water Pump
    Aug 2008
    KCMO
    its either gunna have to be done with a left hand bit and it will actually help it turn the bolt out when your drilling the bit in there. and if that doesnt work then your gunna have to resort to drilling it out and retapping it
  9. #29 Re: Water Pump
    Aug 2008
    Fayetteville, NC
    hmmm...what about a heli coil ? lol make some threads on the broke piece, lock ur bolt in and snatch it out.
    guess thats kinda the same thing u said with a screw...lol
    dremel tool and cut it out...lol
  10. #30 Re: Water Pump
    Jan 2009
    Tallahassee, FL
    those bolts are like impossible to get to (i got the upper right one to move that's it), esp the one on the bottom, how did u get to them?
    I know I did it without much trouble but it was so long ago I have no idea how I did it.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  11. #31 Re: Water Pump
    Aug 2008
    vegas
    into the broken t50? I'd think that's a tall proposition with tool steel.
    you're talking about the pulley down to the right (looking at the motor) at the framerail?
  12. #32 Re: Water Pump
    Dec 2010
    I borrowed one of those hematite magnet rocks from my neighbor's fridge put it next to the t50 bolt and ting, broke t50 piece came right out, pretty unorthodox fix, exchanged the socket and turned it the other way and easy goings from there on out
  13. #33 Re: Water Pump
    Aug 2008
    KCMO
    so now your car is alive?
  14. #34 Re: Water Pump
    Dec 2010
    Quote Originally Posted by carl06GT View Post
    just finishing scraping off the old gasket, it was old, cracked and was like fused to the metal, prob helped the leak a lot lol
    just taking a break since it is like 10 deg outside, fiance made me some hot chocolate
  15. #35 Re: Water Pump
    Aug 2008
    KCMO
    glad to hear man
  16. #36 Re: Water Pump
    Aug 2008
    vegas
    I borrowed one of those hematite magnet rocks from my neighbor's fridge......
    lol --- love it
    and as they say --- necessity is a mother.
    great fix.
  17. #37 Re: Water Pump
    Dec 2010
    car works and doesn't leak anymore yay
  1. Water Pump
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 10:19 PM
  2. Water pump issue
    By josemolina2008 in forum General Tech Discussion
    Last Post: 08-18-2010, 12:47 AM
  3. water pump
    By Ramondo411 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2009, 12:35 AM
  4. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
