Thread: Water Pump
Results 1 to 20 of 37
  1. #1 Water Pump
    Aug 2008
    KCMO
    going to be changing my water pump on my 06 GT this coming week and was wondering how hard it is and if anyone has a step by step diagram on how to tackle the job? the dealership calls for 1.5 hrs so it cant be that bad to do but just want to make sure im not getting into something thats gunna be a pain in the a$$ to do. thanks in advance
  2. #2 Re: Water Pump
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    not sure on my 06, never had to change it. thank god! but my wifes 98 cutlass ( same thing as the malibu ) is a freakin' breeeeezzzeeee....3.1L v6 i believe. Try youtubing waterpump for the 3.8L GM? maybe they're is a video.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  3. #3 Re: Water Pump
    Donating Users NoBoost91's Avatar
    Queens, New York
    im on the hunt for a write up on this too, i just ordered a new water pump
  4. #4 Re: Water Pump
    Aug 2008
    Fayetteville, NC
    here you go.
    YouTube - How To: Water Pump Replacement GM 3800 V6 ( Change / Install for Chevy, Buick, Pontiac, Oldsmobile)
    obviously not the same 3800 thats in your 06 but close enough, basically still same engine....
  5. #5 Re: Water Pump
    Charles City, IA
    Just discoonect the battery.
    loosen waterpump pulley bolts
    remove belt
    remove coolant res for extra room
    remove water pump pulley
    remove water pump bolts
    remove water pump
    clean matting surface on block
    reinstall reverse order
    SMGPFC Two Nipple General
  6. #6 Re: Water Pump
    Aug 2008
    KCMO
    thanks man just never tackled this before and was looking for some insight on it
  7. #7 Re: Water Pump
    Charles City, IA
    They are easy and cheap. you need a 5/16, 8mm,10mm,13mm
  8. #8 Re: Water Pump
    Aug 2008
    KCMO
    cool thanks man.
  9. #9 Re: Water Pump
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    you also need to move the ps pump out of the way. the trick to that are the holes in the ps pulley to loosen the pump from its bracket. you don't have to disconnect the lines --- you just need to move it out of the way to get at the water pump bolts.
  10. #10 Re: Water Pump
    SE Level Member 1998DaytonaPaceCar's Avatar
    Dec 2010
    Lawton / Fort Sill, OK
    Dont forget the t50 socket to remove the s/c idler pulley to get that last long bolt on the bottom right of pump, i had to find this out the hard way...
    1998 Daytona Pace Car #1371 of 1500
    Mods: Pacesetter headers, 3.4" S/C pulley, 180º t-stat, K&N FIPK Intake kit, Cross drilled rotors, 18" rims, DHP PCM, Custom exhaust (Cherry Bomb glasspack acting as resonator, 2X Corsa sport mufflers from my old 06 GTO R.I.P.)
  11. #11 Re: Water Pump
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by Vegas~Blown View Post
    Quote Originally Posted by 1998DaytonaPaceCar View Post
    Do this~!!! Exactly what they said...did mines today...and can confirm this =P
    make sure u scrape ALLLLL of that old gasket off...
  12. #12 Re: Water Pump
    Aug 2008
    KCMO
    how commen is this t50 socket to get the pulley off?
  13. #13 Re: Water Pump
    Aug 2008
    vegas
    Quote Originally Posted by carl06GT View Post
    very.
  14. #14 Re: Water Pump
    Dec 2010
    Which way did u turn the t50 to get the pulley off cause i was told it was reverse threaded and turned it clockwise and snapped off the t50 socket into the pulley bolt, and that was with WD 40, either the bolt is really not reverse threaded or autozone's duralast sockets suck ass...
    So my car is now dead in the water unless i can somehow extract the broken piece out, old water pump is just hanging by that last screw
    Does anyone know if the metal mount thing on the motor the pulley is attached to can be removed, or is it just part of the engine block?
  15. #15 Re: Water Pump
    Jan 2009
    Tallahassee, FL
    Instead of worrying about taking just the pulley off I just removed the mount the pulley is on, only 3 more bolts I believe.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  16. #16 Re: Water Pump
    Dec 2010
    Quote Originally Posted by Sandman View Post
    ^ Hero
    what size bolts were they?
  17. #17 Re: Water Pump
    Jan 2009
    Tallahassee, FL
    Like 10s I guess. It's been a while since I did mine.
    77 Morris Garage B
  18. #18 Re: Water Pump
    Dec 2010
    thx man, gonna go and hopefully get it done before it snows this afternoon lol
  19. #19 Re: Water Pump
    Dec 2010
    those bolts are like impossible to get to (i got the upper right one to move that's it), esp the one on the bottom, how did u get to them?
  20. #20 Re: Water Pump
    Jan 2009
    Tallahassee, FL
    I know I did it without much trouble but it was so long ago I have no idea how I did it.
    77 Morris Garage B
  1. Water Pump
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 10:19 PM
  2. Water pump issue
    By josemolina2008 in forum General Tech Discussion
    Last Post: 08-18-2010, 12:47 AM
  3. water pump
    By Ramondo411 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2009, 12:35 AM
  4. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
