Thread: Flashing check engine light!!
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 120
  1. #1 Re: Flashing check engine light!!
    Damn...even my busted plug never looked that bad LOL
  2. #2 Re: Flashing check engine light!!
    SE Level Member JOGTP's Avatar
    Dec 2010
    Quebec, Canada
    JoshsGTP
    I don't understand what u say. (i speak french)
    "I dont rhink rats fight" ???
  3. #3 Re: Flashing check engine light!!
    Charles City, IA
    I would say your engine is toast. Does not look like the plug melted, something was bashing around in the cylinder. More than likely a chunk of piston.
    SMGPFC Two Nipple General
  4. #4 Re: Flashing check engine light!!
    Charles City, IA
    'What josh ment was "I dont think thats right"
  5. #5 Re: Flashing check engine light!!
    Jul 2008
    sumter,south carolina
    i think he meant that rats live a peaceful life...and dont commit violence on each other?
    02 GTP with mods 05 GP for DD
  6. #6 Re: Flashing check engine light!!
    Dec 2010
    Quebec, Canada
    I bought a long flexible magnet.
    I'll try tom to put it inside the SP hole.
    I don't know if it's a good idea. But i have nothing to lose!
  7. #7 Re: Flashing check engine light!!
    Denver
    If your spark plug looks like that, then your valves will probably also be trashed in that cylinder.
    I think at this point, you're looking at at least one new head and also one new piston.
    Given that it's not the smartest thing to do to teardown and rebuild piecemeal, you'd be better off finding a junkyard motor. You might even look at doing an L32 conversion.
  8. #8 Re: Flashing check engine light!!
    Dec 2010
    Quebec, Canada
    It's already a L32 (2006). with the HD transmission with only 55 000 km
  9. #9 Re: Flashing check engine light!!
    Jul 2008
    Quote Originally Posted by JOGTP View Post
    genV with 3.4 on stock manis... WOW. thought u had genIII blower.
  10. #10 Re: Flashing check engine light!!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    yeah really. 3.4 genV on stock mani's and god knows what for a tune lol
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  11. #11 Re: Flashing check engine light!!
  12. #12 Re: Flashing check engine light!!
    Jul 2008
    replace plugs and see how it runs... like i said. i drove on a chipped piston for awhile..
  13. #13 Re: Flashing check engine light!!
    Maybe put a 4.0" on there...
    Pray really hard too...sometimes there is a God.
  14. #14 Re: Flashing check engine light!!
    Jul 2008
    i said chipped piston in the beginning.... why? because it is/was chipped or even sitting in the oil pan. ive been there and done that. that wasnt a misfire... that vid was missing on a cylinder period.. VIA the whole spark plug electrode gone! and knowing hes running nitrous and a 3.4 pulley on stock manifolds and stock DP. HMmmm not hard to put 2 and 2 together. to call this place clubgp is blasphemy.. feel free to stick around and gain some knowledge on teh 3800. we have several turbo guys here.
  15. #15 Re: Flashing check engine light!!
    Mtl
    Here's some knowlege for you, its not hard to find its IN THE THREAD THAT YOU ARE USING NOW!
    He never used nitrous on his car and he dosent have a stock downpipe!
    You just put 2 and 0 together, you just prouved how the posts looks like the ones on ClubGP!!! Thanks!
  16. #16 Re: Flashing check engine light!!
    Hagerstown,Md
    Quote Originally Posted by GPspool View Post
    But he DID Diagnosis the Issue. So I fail to see your point. Weather it took 2 hours of diagnostics or him hearing the sound for 5 sec. He was correct. If you think its okay to run a 3.4 pulley on a gen V with a cut exhaust and a intake Im sorry to see your a Mod at another GP site. Because your obviously giving out incorrect information
  17. #17 Re: Flashing check engine light!!
    Mtl
    Quote Originally Posted by 01gpgt01 View Post
    But he DID Diagnosis the Issue. So I fail to see your point. Weather it took 2 hours of diagnostics or him hearing the sound for 5 sec. He was correct. If you think its okay to run a 3.4 pulley on a gen V with a cut exhaust and a intake Im sorry to see your a Mod at another GP site. Because your obviuously giving out incorrect information
    How did i give him incorrect information??? Because he bought the car the way it is and he told me he had all the supporting mods on it for a 3.4"??? LOL My bad!
    And how was he correct in the diagnostics? Do you have a pic of a chipped piston i didnt see???
    Like i said before, i know that the chances are slim for the motor being still in good condition but the tests are not all done yet so for now its a cylinder missfire untill theres real proof like a compression test(way better then a celphone vid! lol). AFTER the tests are done then you can give the bad news.... If any.
  18. #18 Re: Flashing check engine light!!
    MA
    ^ plugs a give away.
    if you really want to help this guy then end the bickering before this thread gets closed. simple as that.
    SMGPFC Member #9
  19. #19 Re: Flashing check engine light!!
    Charles City, IA
    hmm I told he to do a compression check in the first place, but I guess he does not want to do that. Must be too much work.
  20. #20 Re: Flashing check engine light!!
    Hagerstown,Md
    Well spark plugs just dont look like a Pit bulls chew toy for any random reason. Theres nothing else to do. Damage has been done. Even if it runs its going to fail eventually. Dont get so butt hurt. Maybe we should just recommend he goes spend 500 dollars in diagnositics and waste countless hours to come up with the same conclusion.
    With the cost being so low on used engines it would be piontless to try to repair. If I pulled a plug out of my car and it looked like that the engine would be pulled the next day. just my 2 cents
    And if you read the first 5 posts it kinda kills your entire argument. Good day. im done arguing over something so stupid
  1. check engine light flashing help
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2009, 07:09 PM
  2. Check Engine Light
    By Alpha388th in forum General Tech Discussion
    Last Post: 02-20-2009, 11:48 PM
  3. check engine light
    By cboth686 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2008, 08:48 PM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  5. Check Engine Light
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2008, 08:28 PM
