Thread: Flashing check engine light!!
Results 1 to 20 of 120
  1. #1 Re: Flashing check engine light!!
    Mtl
    i said chipped piston in the beginning.... why? because it is/was chipped or even sitting in the oil pan. ive been there and done that. that wasnt a misfire... that vid was missing on a cylinder period.. VIA the whole spark plug electrode gone! and knowing hes running nitrous and a 3.4 pulley on stock manifolds and stock DP. HMmmm not hard to put 2 and 2 together. to call this place clubgp is blasphemy.. feel free to stick around and gain some knowledge on teh 3800. we have several turbo guys here.
    Here's some knowlege for you, its not hard to find its IN THE THREAD THAT YOU ARE USING NOW!
    He never used nitrous on his car and he dosent have a stock downpipe!
    You just put 2 and 0 together, you just prouved how the posts looks like the ones on ClubGP!!! Thanks!
  2. #2 Re: Flashing check engine light!!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by GPspool View Post
    But he DID Diagnosis the Issue. So I fail to see your point. Weather it took 2 hours of diagnostics or him hearing the sound for 5 sec. He was correct. If you think its okay to run a 3.4 pulley on a gen V with a cut exhaust and a intake Im sorry to see your a Mod at another GP site. Because your obviously giving out incorrect information
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Flashing check engine light!!
    Mtl
    Quote Originally Posted by 01gpgt01 View Post
    But he DID Diagnosis the Issue. So I fail to see your point. Weather it took 2 hours of diagnostics or him hearing the sound for 5 sec. He was correct. If you think its okay to run a 3.4 pulley on a gen V with a cut exhaust and a intake Im sorry to see your a Mod at another GP site. Because your obviuously giving out incorrect information
    How did i give him incorrect information??? Because he bought the car the way it is and he told me he had all the supporting mods on it for a 3.4"??? LOL My bad!
    And how was he correct in the diagnostics? Do you have a pic of a chipped piston i didnt see???
    Like i said before, i know that the chances are slim for the motor being still in good condition but the tests are not all done yet so for now its a cylinder missfire untill theres real proof like a compression test(way better then a celphone vid! lol). AFTER the tests are done then you can give the bad news.... If any.
  4. #4 Re: Flashing check engine light!!
    MA
    ^ plugs a give away.
    if you really want to help this guy then end the bickering before this thread gets closed. simple as that.
    SMGPFC Member #9
  5. #5 Re: Flashing check engine light!!
    Mtl
    Quote Originally Posted by SilvaMan61 View Post
    THE point IS that ALL the diagnostics where made BEFORE anyone saw the plugs!
    And i am THE only one realy helping him since I'M the one going to his house to work on his car!
  6. #6 Re: Flashing check engine light!!
    MA
    i think he got a fair share of help here too pal. All im saying is drop it before the tread gets locked up.
    SMGPFC Member #9
  7. #7 Re: Flashing check engine light!!
    Akron Ohio
    Quote Originally Posted by JOGTP View Post
    What wrong with my car? Flashing check engine light code P0306
    He asked what might be wrong? We told him what we thought.
    point was that the diagnostics was made WAY BEFORE any test or inspection was done so there was a few possible things that could make a cylinder misfire and if i ever see someone do that in my hydraulic shop(tell a client his hydraulics are dead before he even looks at it) i would fire his ass.
    Its just not how i work, right or wrong its always: 1-test/inspect, 2-diagnose/fill a report, 3- Repare(if not scrap) 4- test, 5- On to the next one you lazy bum!
    once again, He simply asked what night be wrong and offered no other data.
    we told him what MIGHT BE WRONG!
    Good then go fix it and STFU.
    I mean Christ DUDE, if your going to fix it why post all the bull**** on here.
    He offered no other info then a video and saying, ''whats wrong with my car''
  1. check engine light flashing help
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2009, 07:09 PM
  2. Check Engine Light
    By Alpha388th in forum General Tech Discussion
    Last Post: 02-20-2009, 11:48 PM
  3. check engine light
    By cboth686 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2008, 08:48 PM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  5. Check Engine Light
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2008, 08:28 PM
