Yup chipped pistons blow. I chipped a piston on a 3.5 with a down pie, cai,1.0pcm,ect. We may be dicks, but when you are on your 3rd or whats nick up to 6th? engine you start to get **** figured out.
What headers r the best for my car ?
T.O.G. / SLP / PaceSeeter / ZZP / Other
speed daddy- your welcome
ZZP's are the best right now.
But they cost the most.
SD's will seal, most of the time.
The flex leaks and the DP sucks.
sorry for the hijack but i been lookin into headers too and i wanted to know if u can fix the flex section and what about the dp sucks?
^ getto dp modding... i like
Supposing your right...i chip a piston. What i can do now?
drive it till it blows up or get a new short block.
I will have pics in a few weeks on a great fix for the dp.
I taked off the spark plug no.6. The spark plug lost his head!What should I do ? Compression test?? Put a magnet into the spark plug hole and pray to find something?? Only install new spark plug?? Buy a G8 GXP supercharged?? lol!!
yep u chipped a piston bro... u may continue to drive it like that forever... or it may grenade any day..do a compression test and GET THAT 3.4 OFF asap. pull all plugs and replace them all... chances are the others are bent or broken also... u can still drive the GP but STAY OUT OF BOOST until u get that pulley off or until u get some breathing mods.
Mmmm...
see my first post on page 1.
Did I call it or did I call it.
GTPINSC
What u mean by breathing modds?
What sparks plugs r the best?
I have Autolite 104 (not install)
I would check and see if you still have a piston before you worry about spark plugs.
refer to post #5
i think he just chipped it... when i sent my pistons on vacation to the oil pan.. it sounded alot worse than his vid
beathing mods are headers, plog, downpipe, intake .... your best bet is to get headers. and it really depends on the plugs... if u get a stock pulley on .. go with autolite copper 605 or 606 heat range... if u get headers or a downpipe... get some new autolite copper 104's.my advice is get a mechanics scope and look into the cylinder and see how bad the chip is before u make any further decisions on the car.
sucks.. run a compression test
