Thread: Flashing check engine light!!
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 120
  1. #1 Re: Flashing check engine light!!
    Well...if the electrode is gone on the plug...kinda a waste of time to do a compression test...since we already know he needs a new bottom end.
  2. #2 Re: Flashing check engine light!!
    GTP Level Member KwazrollinZ28GTP's Avatar
    FLINT/michigan
    I WANT PICTURES!!!!! lol
    1997 GTP 2DR RaceKAR
    1994 Z28 intake, small cam, exhaust leak
    2000 silverado 5.3l Z71 3.73gear posi, 3.5" lift 33" tires DIABLO Tune
  3. #3 Re: Flashing check engine light!!
    Jul 2008
    sumter,south carolina
    nick when i chipped piston/broke plug. i drove for awhile on it. would prob still be on that same motor if i wasnt lazy and would have replaced cat... i didnt feel a power loss after it happened and had no smoke coming out of exhaust.... got into it a lil too hard one day passing someone and finished it off.
    02 GTP with mods 05 GP for DD
  4. #4 Re: Flashing check engine light!!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    LOL, That guy on the Canadian linked forum Turbo Gp was calling us idiots when a chipped piston was brought up..... Opps. The Motors toast, Learn from your mistake and put in a used long block
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: Flashing check engine light!!
    Jul 2008
    Quote Originally Posted by 01gpgt01 View Post
    then this dude... wonder what he was LOL'ing at?
    Quote Originally Posted by 2003 SSEi View Post
    people in this thread make me LOL,
    the Flashing light is not always a misfire its a "catalyst damaging condition" So yes it COULD be a misfire, there are other things that will cause the Flashing MIL.
    i melted (not smashed) a plug and dont have any piston damage....imagine that
    there is a very good chance his engine is fine.
  6. #6 Re: Flashing check engine light!!
    SE Level Member JOGTP's Avatar
    Dec 2010
    Quebec, Canada
    Can u tell me why i'm not able to add pics? IT's always tell me Upload of file failed.
  7. #7 Re: Flashing check engine light!!
    Mtl
    LOL at another ClubGP style answer which is what i was LOLing at from the start. Maybe its your translator thats not working but i never called anyone a idiot for saying its a chipped piston, in fact in that same post i said it myself it could be a chipped piston BUT you need to do a few easy basic tests first. THE GUY DIDNT EVEN CHECK ANYTHING YET! He didnt check his spark plug wires or spark plugs and people here where trying to make him panic and saying you chipped a piston or blew your motor! My LOL was at the ClubGP style stupid answers where people think there cool for making a guy panic with the worst plausible thing out of a bad 15 second cell phone vid without even trying to help him at all.
    If this was your best friend that came to your house and tell you he has rough idle and missfires would you tell him to replace is motor without even poping the hood to look at 2 easy basic things first?!?
    I'm shure that when you have missfires you change your motor without checking anything first right smart guy?
    Making the guy panic dosent help anything, before doing the ClubGP thing and saying that his motor is dead i was trying to help him do a few easy test to have a better idea of what was realy the problem.
    Now that i see that he was still using his original OEM spark plugs and how the plug that he pulled looks i know that theres a very slim chance that his motor is still in good condition BUT theres is still that slim chance... The compression test will probably confirm what we already know but still leave the guy a bit of hope even if its super fun and cool to tell a guy is engine is toast
    FYI, Even with headers if you have a bad tune and have your stock OEM spark plugs you can still pop a piston with a 3.4"
  8. #8 Re: Flashing check engine light!!
    Hagerstown,Md
    Quote Originally Posted by GPspool View Post
    Yap yap yap, Point is he Got what he came for. A diagnosis. Might not have been what he wanted to hear.
  9. #9 Re: Flashing check engine light!!
    Mtl
    Might not even be correct since it was a blind shot in the dark lol
    Dont bother checking your wires or sparkplugs if you have a cylinder missfire Change the engine!
    Of course you're not gonna be wrong, the car's gonna run better if it has a new motor with all the wires plugged in correctly!
    At one point someone is gonna come here with a cylinder missfire and get the same advice but the only problem he's gonna have is a unplugged sparkplug wire and he will get the usual "chipped a piston!" or "your motor is toast!"
    Step 1- tests
    Step 2- diagnostics
    Step 3- brag about being right
  10. #10 Re: Flashing check engine light!!
    Dec 2010
    Quebec, Canada
    I heard so many differente version lol. Do u think guys it's a good idea to put a little magnet into the spark plug hole ?
  11. #11 Re: Flashing check engine light!!
    Jul 2008
    you need to use a hosting site like photobucket or imageshack then post the [img] code.
    more than likely the piece of piston is in the oil pan or exited through the exhaust.
  12. #12 Re: Flashing check engine light!!
    Dec 2010
    Quebec, Canada
    BlueGTP91
    It's happen in August n the temp was normal.
  13. #13 Re: Flashing check engine light!!
    Jul 2008
    still... a 3.4 pulley is too much for stock exhaust manifolds. if u drove it in teh winter like that... all of your pistons would prob be in the oil pan.
  14. #14 Re: Flashing check engine light!!
    Charles City, IA
    go to an auto store and rent a leak down gauge and test that cylinder.
    SMGPFC Two Nipple General
  15. #15 Re: Flashing check engine light!!
    Dec 2010
    Quebec, Canada
    Here the link to see 3 pics of my broken spark plug.
    Spark Plug pictures by JoGTP - Photobucket
  16. #16 Re: Flashing check engine light!!
    Dec 2010
    Quebec, Canada
    Don't worry GTPINSC !
    I drive a winter beater (Toyota Tercel 98' )
  17. #17 Re: Flashing check engine light!!
    Jul 2008
    ouch. did you check the rest of them?
  18. #18 Re: Flashing check engine light!!
    Akron Ohio
    I dont rhink rats fight
  19. #19 Re: Flashing check engine light!!
    Jul 2008
    Quote Originally Posted by JoshsGTP View Post
  20. #20 Re: Flashing check engine light!!
    Akron Ohio
  1. check engine light flashing help
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2009, 07:09 PM
  2. Check Engine Light
    By Alpha388th in forum General Tech Discussion
    Last Post: 02-20-2009, 11:48 PM
  3. check engine light
    By cboth686 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2008, 08:48 PM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  5. Check Engine Light
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2008, 08:28 PM
