Thread: Need help finding out what i need to fix! P0303 and P0171 codes
Results 1 to 8 of 8
  1. #1 Need help finding out what i need to fix! P0303 and P0171 codes
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    So i have had my Grand prix GTP for a few weeks now and we have been trying to find out what should be replaced to make the two codes i have go away. The codes came on after i went WOT and then let off and the codes are P0303 Cylinder 3 misfire and P0171 system too lean. I have been told many things like i should replace my plug wires and plugs, i should search for a vaccume leak somewhere, and also that i have a lazy upstream oxygen sensor. so i am wondering if any of you all have had this problem and could help me find out what i have to replace to make the codes go away so i can get an emissions test done soon. Thanks
  2. #2 Re: Need help finding out what i need to fix! P0303 and P0171 codes
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by Spartanzz View Post
    With any misfire, check spark plugs, wires and coils. If you have P0171, you probably have a big vacuum leak. Do you have access to a scanner? If so, scan your IAC values at idle (after car is warm). They should be between 45 and 55. 01gpgt01 gave me this tip, and I found my vacuum leak an fixed my P0171 code. Also, scan your O2 values. That will indicate if there is a problem there.
  3. #3 Re: Need help finding out what i need to fix! P0303 and P0171 codes
    Umm...
    This sounds like your stereotypical piston chipped scenario.
    WOT + lean = misfire code?
    Pull the plug and hope its not bent.
  4. #4 Re: Need help finding out what i need to fix! P0303 and P0171 codes
    Umm...
    Never thought of that. Matty boy, you're so smart. Haha.
  5. #5 Re: Need help finding out what i need to fix! P0303 and P0171 codes
    Dec 2010
    Lawrenceville, GA
    ok wellthe other thing is it did go off for a tad after a while of relaxed driving but came back after i did go wot. the other thing is the car idols perfectly fine other than the rattle i have from the supercharger coupler i need to replace so i wouldn't think it would be a big leak iv checked the coil and it does give off a spark but i have to check the plug on it. also just have to check myself on this but am am i right on the middle cylinder on the front of the engine being cylinder 3? thats the one thats saying is misfiring and i also have a friend who swares that the upstream O2 sensor is whats causing both error codes...
  6. #6 Re: Need help finding out what i need to fix! P0303 and P0171 codes
    bad upstream messes things up.
    Have you pulled the plug yet?
    It could be a bad wire or something simple like that.
    Front middle is #3.
  7. #7 Re: Need help finding out what i need to fix! P0303 and P0171 codes
    Dec 2010
    Lawrenceville, GA
    yes he says its the upstream o2 sensor throwing the codes and causing this mis fire. And i havent pulled the plug just yet going to do it tomorrow once i have a second.
  8. #8 Re: Need help finding out what i need to fix! P0303 and P0171 codes
    Charles City, IA
    Bad plug wont cause A lean code, I am leaning towards a fuel injector.
    SMGPFC Two Nipple General
  1. s/c gasket leaking setting p0171
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 04:56 PM
  2. Bad idle and RPM issues not to forget codes P0303, P0341, AND P0300
    By jessiinicole in forum Off Topic Discussion
    Last Post: 03-08-2010, 02:27 PM
  3. Code P0303, and p0300
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 09:08 AM
  4. P0303 - Cylinder #3 Misife ...
    By 98GP*GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2008, 01:23 PM
  5. P0171 set on decel//update has another code
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2008, 11:59 PM
