Thread: Need help finding out what i need to fix! P0303 and P0171 codes
Results 1 to 8 of 8
  1. #1 Re: Need help finding out what i need to fix! P0303 and P0171 codes
    Umm...
    This sounds like your stereotypical piston chipped scenario.
    WOT + lean = misfire code?
    Pull the plug and hope its not bent.
  2. #2 Re: Need help finding out what i need to fix! P0303 and P0171 codes
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Umm...
    Never thought of that. Matty boy, you're so smart. Haha.
  3. #3 Re: Need help finding out what i need to fix! P0303 and P0171 codes
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    ok wellthe other thing is it did go off for a tad after a while of relaxed driving but came back after i did go wot. the other thing is the car idols perfectly fine other than the rattle i have from the supercharger coupler i need to replace so i wouldn't think it would be a big leak iv checked the coil and it does give off a spark but i have to check the plug on it. also just have to check myself on this but am am i right on the middle cylinder on the front of the engine being cylinder 3? thats the one thats saying is misfiring and i also have a friend who swares that the upstream O2 sensor is whats causing both error codes...
  1. s/c gasket leaking setting p0171
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 04:56 PM
  2. Bad idle and RPM issues not to forget codes P0303, P0341, AND P0300
    By jessiinicole in forum Off Topic Discussion
    Last Post: 03-08-2010, 02:27 PM
  3. Code P0303, and p0300
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 09:08 AM
  4. P0303 - Cylinder #3 Misife ...
    By 98GP*GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2008, 01:23 PM
  5. P0171 set on decel//update has another code
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2008, 11:59 PM
