Thread: s/c gasket leaking setting p0171
Results 1 to 4 of 4
  1. #1 s/c gasket leaking setting p0171
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    ok so i finally found a vac leak it is coming from the snout side of the blower where the s/c and lim meet the gasket is new and so is the lim any ideas on how to fix this leak double up the gasket use rtv? please leave ideas
    ps its a garlock gasket and i herd they are garbadge
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: s/c gasket leaking setting p0171
    Pretty sure we went over this last night but I'll toss it out there again.
    Either buy Felpro or GM OEM gaskets...even though Garlocks are really cheap...you get what you pay for obviously...same thing happened with mine except it leaked around the coolant passes by the TB. You NEVER want to double gasket the S/C...it won't seal for sh1t...same with RTV'ing it...that's no good...don't ghetto rig it. Just clean the LIM and bottom of the blower good...make sure there are no pieces of gasket left over on either side...because if there are...that could be screwing up the seal on it too.
  3. #3 Re: s/c gasket leaking setting p0171
    ya the lim is new and a scraped all the old gasket off the s/c and cleaned it with break clean so i guess im changing it again lol
    sold 97 GTP stock
  4. #4 Re: s/c gasket leaking setting p0171
    well i replaced gasket with ome from gm and it works great no leaks
    sold 97 GTP stock
  1. setting up new system
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2009, 11:27 PM
  2. Gasket/Leaking problem
    By Phil_GTP in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:48 PM
  3. Setting up account
    By PWNED in forum PCM Tuning
    Last Post: 08-23-2008, 06:29 AM
  4. P0171 set on decel//update has another code
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2008, 11:59 PM
  5. Hood not setting right.
    By DanGTP in forum Visual/Body Modifications
    Last Post: 03-02-2008, 01:43 AM
