Yes two flanges, one on cat, one on resonator. The bolt head is on the cat side for sure. No nut on the resonator side, maybe threaded flange. My best guess is bolt head is welded on cat side, but then there should be a nut on resonator side.
If I cut off the head on cat side I assume all will slide off unless it is pressed in which means I should cut off the resonator side.
Any feedback on which side to cut cat side or resonator side.
