Thread: Cat back replacment (How to remove)
Results 1 to 8 of 8
  1. #1 Re: Cat back replacment (How to remove)
    Donating Users
    South Deerfield, MA
    The two flanges are not a slip fit. They but up against each other with a gasket in between them. If you only see a hex head on the cat side, then it is either a nut attached to a stud from the resonator side or a bolt threaded into the flange on the resonator side. Mine had the resonator replaced before I bought the car so the flanges had holes on both sides with a bolt and a nut holding them together.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  2. #2 Re: Cat back replacment (How to remove)
    Nov 2010
    Well I cut through the hex head on cat side, and it is for sure not a nut (no thread). On the resonator side I ground flush to backside of flange, and it must be threaded into resonator flange as the flange will not break loose.
    I will keep grinding and cutting till it comes loose, just a very strange joint with no clearence holes in the flanges.
    When done I guess I will have two holes in each flange.
  3. #3 Re: Cat back replacment (How to remove)
    Nov 2010
    I ground down flush with flange on both sides, and still do not see a hole. You can see the ring of the bolt on both flanges, but will not break. Guessing it is a pressed in stud on one side and threaded flange hole on other, but no way this could be.
  4. #4 Re: Cat back replacment (How to remove)
    Donating Users
    South Deerfield, MA
    You might have to drill out the cat side to attach the bolt for your new cat back. Sounds like it might have rusted together.
  1. Remove back speaker of a 2005 Grand prix base.
    By Lentrave in forum Audio, Security & Visual Electronics
    Last Post: 09-08-2009, 07:32 PM
  2. need help getting my back window back on track
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 06-15-2009, 04:06 PM
  3. how do you remove the back seat?
    By 2000GTP in forum General Tech Discussion
    Last Post: 10-26-2008, 08:11 PM
  4. how to remove the back speakers...
    By bb52190 in forum Off Topic Discussion
    Last Post: 10-09-2008, 07:47 PM
  5. Can't remove key
    By GrandPrixlbc in forum General Tech Discussion
    Last Post: 08-08-2008, 06:30 PM
