Thread: scratcy intake noise
Results 1 to 3 of 3
  1. #1 scratcy intake noise
    SE Level Member jersey jok3r's Avatar
    Northern New Jersey
    I have this noise coming from my intake area on low rpm, like driving around neighborhood streets that sounds like a shovel being dragged across concrete only at low rpms though. Does not make the sound at idle. Is it the coupler or the IAC valve. Its annoying as shyt
    Ported Outlet/Inlet,3.4 pulley,ZZP PLOG, ZZP 3"DP,U bend delete, K&N CAI, ZZP wires,high-flow CAT, ZZP TB Spacer, Autolite iridium 104s,180tstat, OVERKILL PCM, Borla Cat Back system, Black Halo HIDS, Phantom autometer gauges
  2. #2 Re: scratcy intake noise
    Vancouver, WA
    Well the couple should only make that noise at idle if that's the problem
  3. #3 Re: scratcy intake noise
    Its called deal with the 3800 IAC...there are all like that. If you dont like it put the factory intake back on.
  1. Engine noise from intake...REALLY loud..
    By putskijr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2010, 09:26 PM
  2. GTP Noise....
    By SuperCharged0nE in forum General Tech Discussion
    Last Post: 04-02-2010, 12:01 PM
  3. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  4. question about noise with my intake?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2008, 08:37 AM
