Thread: 2004 supercharged won,t pass 3500rpm
Results 1 to 13 of 13
  1. #1 2004 supercharged won,t pass 3500rpm
    IL, USA
    I'm a newbie on supercharged sys. So I'll appreciate some ideas what to check before I have to take it to the shop. so far I just check the gas pump and it has pressure, when riding it it runs fine but it won't pass 3500rpm and I can't hear the supercharger kicking in.... any ideas thanks
  2. #2 Re: 2004 supercharged won,t pass 3500rpm
    cat clogged magically?
  3. #3 Re: 2004 supercharged won,t pass 3500rpm
    IL, USA
    thanks I'll check it first thing 2morrow
  4. #4 Re: 2004 supercharged won,t pass 3500rpm
    you know how?
    *hint:create an exhaust leak before the cat*
  5. #5 Re: 2004 supercharged won,t pass 3500rpm
    IL, USA
    you know how?
    loosening the bolts ?
  6. #6 Re: 2004 supercharged won,t pass 3500rpm
    that'll do
  7. #7 Re: 2004 supercharged won,t pass 3500rpm
    IL, USA
    thanks I'll post the results
  8. #8 Re: 2004 supercharged won,t pass 3500rpm
    Akron Ohio
    make it easy for yourself and just take out the top o2 sensor
  9. #9 Re: 2004 supercharged won,t pass 3500rpm
    Charles City, IA
    Quote Originally Posted by joshsgtp View Post
    QTF
    SMGPFC Two Nipple General
  10. #10 Re: 2004 supercharged won,t pass 3500rpm
    IL, USA
    I'm afraid its the super charger, it is making an sporadic clanking noise when it reaches the 3500 rpm, releasing gas a little and works fine any body knows a decent place for buying a new or restored one?
  11. #11 Re: 2004 supercharged won,t pass 3500rpm
    Its not the supercharger...they don't just GO BAD. Try again...prolly a clogged cat...a clogged cat is HUGE symptoms for cars dogging trying to get up to speed. Any check engine lights?
  12. #12 Re: 2004 supercharged won,t pass 3500rpm
    IL, USA
    thanks for the answer.... no warning lights, and what really worries me is that knock and clank noise that comes from around the supercharger area when it reaches 3500 rpm (pedal to the bottom) just check oil level on super charger yesterday it was missing half, so I drain it, it had a really bad smell, my local dealer just had 1 bottle in stock. I'll get more 2morrow. I'm also checking the compression on all cylinders around 155 on 4 of them so far (2 left on back are proving to be a pain in the arse lol ) thanks again
  13. #13 Re: 2004 supercharged won,t pass 3500rpm
    Get a video of it.
  1. 97-03 GP pass. floor wet
    By Street Dreams CC in forum General Tech Discussion
    Last Post: 10-10-2018, 09:56 PM
  2. Cant pass echeck!!
    By mxthunder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 05:48 PM
  3. 2004 lincoln Lsv8 or 2004 GP GTP?
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-10-2009, 03:58 PM
  4. my 12 sec pass
    By zexed99gt in forum Track Sessions and Kills
    Last Post: 01-08-2009, 10:48 AM
  5. Boost by pass
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:35 PM
