Thread: refresh or engine swap?
Results 1 to 10 of 10
  1. #1 refresh or engine swap?
    SE Level Member bstuby's Avatar
    charleston, IL
    my 98 gtp has 193000 on it and im not exactly sure what to do. the car is bone stock with a custom cai but i want to do more mods. Nothin extreme at the moment just a 3.4 pulley and supporting mods. i already changed lower intake gaskets, tb, s/c, valve cover and new o rings on the injectors. my worry is is that if i start doin those mods that somethins goin to give out cause of the high mileage. so do u think a refresh would be good and just take a look a the rod bearings to see if they need to be replaced? or just say the hell with it and buy a lower mileage engine and just go from there?
    Thanks for your time
  2. #2 Re: refresh or engine swap?
    Only thing I'd worry about next is the timing chain and tensioner. Other than that...next thing would be possibly the oil pan gasket/water pump...but these bottom ends run forever...there was a guy on here...not sure if he still has the car but it was a rockered/IC/header car...1997 and it had nearly 300K on it...he replaced the transmission in it though I think...that will be the next thing on your list but the bottom ends are virtually bulletproof unless your me or kfish. We've probably blown up 15 between the 2 of us.
  3. #3 Re: refresh or engine swap?
    charleston, IL
    Holy crap...that's quite a few engines but yea I do have a oil leak and its gettin worse. I thought it was the valve cover gaskets but they are replaced. I looked under the engine and the oil pan is soaked so that leads me to belive that its the oil pan now. The car still runs strong except for a vibration I can't pinpoint. It only does it at idle in gear or drive I was thinkin possibly motor mounts but not sure. I'm gonna rebuild the transmission at some point but if its still holdin up too
  4. #4 Re: refresh or engine swap?
    Bonaire 31005
    If you can do the work yourself i say rebuild the engine.
  5. #5 Re: refresh or engine swap?
    charleston, IL
    I can do the rebuild myself but its my daily driver and i dont want it down for that long. Thats why i was leaning more torward the refresh so then it wouldnt be down for nearly as long. I wasnt wanting to go crazy on it....yet. I just want some extra hp
  6. #6 Re: refresh or engine swap?
    Donating Users kfish's Avatar
    Ohio
    do not do a rebuild. finding a low mileage motor is much cheaper. gaskets alone are about 300 for a full gasket set. piston rings are another 100, plus every bolt in the bottom end is tty.
  7. #7 Re: refresh or engine swap?
    I'd rebuild them a million times after the luck I've had and you should be saying the same thing Kristina. Cmon now. Plus...if he buys ARP main and head studs he will never have to buy them again.
  8. #8 Re: refresh or engine swap?
    machine work + time + gaskets and bearings and rings are not worth it imo.
  9. #9 Re: refresh or engine swap?
    It's worth it if he toasts another few engines.
  10. #10 Re: refresh or engine swap?
    charleston, IL
    lol thats so very true blue
  1. engine swap
    By NR92 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-08-2010, 10:39 PM
  2. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  3. swap to a non sc engine?
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-18-2009, 06:07 PM
  4. 150K suspension refresh
    By Smokin2000gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 08:14 PM
  5. Help!! Tranny Swap Engine ''Refresh''
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-10-2008, 12:04 PM
