Thread: engine swap
Results 1 to 4 of 4
  1. #1 engine swap
    GT Level Member NR92's Avatar
    Atkins, Ia
    hey im new here, i own 2 99 v6 cougars but thats not why im here
    my uncle has a 98ish olds 88 with a 3800 and from what he tells me it blew a head gasket then spun a bearing.... and he has asked me to put a new engine in it for him, im not new to engine swaps but i am to gm engines can anyone give me an idea on to what major things i will have to pull when i pull the engine, do i have to pull the trans out with it? what accessories can stay with the engine when it comes out? what should i do to the engine before i put the new one in? what should be transfered to the new engine (waring harness, sensors, exc)
    im pulling the engine regardless i would just like to get an idea on what im getting into
    thanks in advance for the help
  2. #2 Re: engine swap
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    i believe most of the wirting will stay with the car, i would take off all assesories, starter, alt, ac pump, power steering pump....undo wiring, i believe most things unplug. i think the fuel injectors unplug as a whole....there are a few grounds on the bell housing bolts. there is a "*****" bolt as a bellhousing bolt and its between the trans and engine block in the rear of engine but u have to get to it from the pass side with a long extension or extensions....(18mm) there is also a bracket/mount on the transaxle to engine on the pass side which you can remove to help get the "*****" bolt. also the oil filter housing has to be removed pretty sure.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: engine swap
    Atkins, Ia
    ok lol that doesnt seem to bad so i can get this engine out easily in a day
  4. #4 Re: engine swap
    Charles City, IA
    yeah they are not bad at all.
    SMGPFC Two Nipple General
  1. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  2. Engine Swap
    By TowerLadder43 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-28-2009, 07:37 PM
  3. Engine Swap
    By swapthe98 in forum Engine
    Last Post: 09-26-2009, 11:41 PM
  4. engine swap
    By the1mg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 03:36 PM
  5. L36 engine swap
    By themagicdustman in forum General Tech Discussion
    Last Post: 02-05-2009, 07:08 AM
