Have fun getting those bolts back out with red loctite on them. Did you hook the icm ground back up under the coils? I bet you didnt, I did the same thing when I did my heads and rockers.
that bolts to the head right?
yup under the icm bracket. I cut mine off and ran it directly to battery ground.
Nvm I found that I mix up the 3 and 5 cylinder wires. Thanks for the help!
I had re installed the stock rockers so yeah the noise went away.
