Thread: Which one should I buy?
Results 1 to 13 of 13
  1. #1 Which one should I buy?
    Minnesota
    Trying to decide between two widebands. I know there are threads saying opinions but I wanted to see what you guy think. These are the lowest prices I could find and by what I saw that two best options:
    PLX:
    PLX DM-5 Wideband O2 52mm Display + SM-AFR Combo BLACK: eBay Motors (item 390177902502 end time Oct-28-10 14:27:24 PDT)
    OR
    NGK:
    NGK NTK Wide Band Powerdex AFX Air/Fuel Gauge Wideband: eBay Motors (item 400161776545 end time Oct-17-10 08:56:10 PDT)
  2. #2 Re: Which one should I buy?
    Charles City, IA
    I have the afx and it works great for me.
    SMGPFC Two Nipple General
  3. #3 Re: Which one should I buy?
    Minnesota
    I have two votes for the NGK AFX at this point. I just liked the gauge on the PLX.
  4. #4 Re: Which one should I buy?
    Akron Ohio
    I like the PLX
  5. #5 Re: Which one should I buy?
    Minnesota
    I am leaning toward that PLX because its a good price and has some better options.
  6. #6 Re: Which one should I buy?
    do you happen to have an aeroforce?
  7. #7 Re: Which one should I buy?
    Minnesota
    I do not have an aeroforce. To be honest I don't really like the pillar mounts. Mainly cause I can't find a two pod pillar mount for my car. I was actually thinking I would run one of the PLX wifi or PLX Kiwi adapters and use my phone as the gauge.
  8. #8 Re: Which one should I buy?
    Jan 1970
    Maquoketa, Iowa
    I have a PLX M300. Either of those would work. I think there are some used AEM widebands in the for sale section or on clubgp.com for $175 though as well.
  9. #9 Re: Which one should I buy?
    Minnesota
    Yeah I have seen only bad reviews of the AEM brand widebands. From the research I have done the PLX and NGK widebands are the best for that price point.
  10. #10 Re: Which one should I buy?
    Bonaire 31005
    I like the AFX better.
  11. #11 Re: Which one should I buy?
    Minnesota
    Quote Originally Posted by FastestGTP View Post
    Why do you like it better?
  12. #12 Re: Which one should I buy?
    Bonaire 31005
    Quote Originally Posted by Pure2sin View Post
    Larger display that makes it easier to read. I'm sure they are both well made and work like they should. Plus I can mount it anywhere I want. Not just in a gauge pod. I mounted mine when I had it right on top of the dash above the instrument cluster so its easier to see when I need to see it.
  13. #13 Re: Which one should I buy?
    Minnesota
    I just read something that made my mind up. With the PLX wideband you don't need to open air calibrate it like you would with the AFX.
buy
