Vacuum leak. Did you use any RTV on the blower gasket? I always used RTV black on it running a 1/16 bead arount the blower outlet on both sides of the gasket. Then I smear it in a circular motion. Works every time. Spray bottle plus soapy water will help find the leak. With a whistle you could just try to listen and isolate the leak. Good luck.
