Thread: getting headers. what do i all need?
Results 1 to 20 of 28
colindunn getting headers. what do i... 09-13-2010, 05:03 PM
CTKGP09 Re: getting headers. what do... 09-13-2010, 05:21 PM
NineD9GT Re: getting headers. what do... 09-13-2010, 05:24 PM
CTKGP09 Re: getting headers. what do... 09-13-2010, 05:34 PM
colindunn Re: getting headers. what do... 09-13-2010, 05:38 PM
CTKGP09 Re: getting headers. what do... 09-13-2010, 05:40 PM
colindunn Re: getting headers. what do... 09-13-2010, 05:44 PM
CTKGP09 Re: getting headers. what do... 09-13-2010, 10:31 PM
Abrasive Re: getting headers. what do... 09-15-2010, 12:00 AM
Ricky21 Re: getting headers. what do... 09-15-2010, 03:32 AM
NineD9GT Re: getting headers. what do... 09-13-2010, 06:41 PM
Ricky21 Re: getting headers. what do... 09-14-2010, 12:41 AM
rynoman03 Re: getting headers. what do... 09-15-2010, 04:01 AM
CTKGP09 Re: getting headers. what do... 09-15-2010, 02:07 PM
NineD9GT Re: getting headers. what do... 09-15-2010, 02:35 PM
Bio248 Re: getting headers. what do... 09-15-2010, 03:07 PM
Abrasive Re: getting headers. what do... 09-16-2010, 06:31 PM
blueguy Re: getting headers. what do... 09-16-2010, 06:47 PM
NineD9GT Re: getting headers. what do... 09-17-2010, 11:00 AM
DCVING Re: getting headers. what do... 09-17-2010, 01:17 PM
blueguy Re: getting headers. what do... 09-17-2010, 03:47 PM
Ricky21 Re: getting headers. what do... 09-17-2010, 03:52 PM
blueguy Re: getting headers. what do... 09-17-2010, 04:00 PM
DCVING Re: getting headers. what do... 09-17-2010, 04:46 PM
Perry125 Re: getting headers. what do... 09-19-2010, 08:06 PM
Bio248 Re: getting headers. what do... 09-19-2010, 08:57 PM
blueguy Re: getting headers. what do... 09-20-2010, 08:20 AM
Perry125 Re: getting headers. what do... 09-20-2010, 08:29 PM
  1. #1 getting headers. what do i all need?
    GTX Level Member colindunn's Avatar
    Aurora, IL
    im getting some SD headers off ebay and am installing myself. i know its not easy but i can still do it. i know its recommended to purchase new clamps instead of the ones they give you. but do i need anything else like any special tools? i have sockets, wrenches, etc.. what kind of penitrator should i use for the bolts? just looking for some tips from people who know this more than i do to make the process easier. any tips will help. thanks
  2. #2 Re: getting headers. what do i all need?
    Willoughby, Ohio
    pb blaster worked for me, ratching wrenches and u-joint sockets are nice to have and will make the install go smoother but are not required, some people will recommend copper RTV to seal the joints as well
    and have something to strap your engine to keep it rocked forward for the rear header to fit
  3. #3 Re: getting headers. what do i all need?
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    My bolts came right out without any oil, but I like PB blast. Id use gm manifold gaskets instead of the ones that come with it. I also used some copper rtv on the joints, if they are still the slide on type. If you can get the old off, you can get the new on.
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  4. #4 Re: getting headers. what do i all need?
    Willoughby, Ohio
    i bought the DNA headers and they came with nice gaskets so i was able to use new one but the stock ones for the head will work fine
    however you will probably need a new one for the downpipe because mine was crappy and fell apart when i took it out
  5. #5 Re: getting headers. what do i all need?
    Aurora, IL
    awesome thanks. yeah i heard use alot of copper rtv to prevent leaks and to just get new GM gaskets for the best seal. i think im going to get the speed daddy headers. will that just bolt up to my stock cat back? (where the DP from the new headers meets the section before the stock resonator)
  6. #6 Re: getting headers. what do i all need?
    Willoughby, Ohio
    yes, all bolt on
  7. #7 Re: getting headers. what do i all need?
    Aurora, IL
    what about my rear o2 sensor? im deleting my cat but want to keep the o2. is there a hole for that or do i need to modify that also? i know i have to buy an o2 extension from zzp for the front one.
  8. #8 Re: getting headers. what do i all need?
    Willoughby, Ohio
    Quote Originally Posted by colindunn View Post
    there will be 2 bungs for both O2 sensors but if theres no cat the SES will come on so it needs to be deleted from the PCM
    you can buy the extension but i just took extra wire and did it myself for free
  9. #9 Re: getting headers. what do i all need?
    Odessa, MO
    Quote Originally Posted by CTKGP09 View Post
    X2, I always just splice in about 18" of new wire for the extension.
    His rear O2 codes are already turned off in his dhp pcm, so he is good to go there.
    As for the Speed Daddy headers, I have installed a few sets and the rear O2 location has never given me much trouble. There is a bung for the sensor right in front of the cat-back flange. The only issue I have had with it's location is that the big fat rubber rings that the exhaust hangs on are right there too. The one side can be hard to get on right next to the sensor.
    The front O2 location is another story. Terrible location and almost always ends up so close to the floor that the sensor won't even go in without beating a dent in the floor of the car. I recommend just plugging that bung and having a new bung welded in at a better location. The top of the crossover pipe is nice, and then you don't even need an O2 extension at all.
  10. #10 Re: getting headers. what do i all need?
    Minnesota
    Quote Originally Posted by Abrasive View Post
    Can you really put the o2 there? I just changed mine on my headers and it was a ***** i thought i needed a new o2 bung but finally got it after tapping it with a spark plug tap
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  11. #11 Re: getting headers. what do i all need?
    Dec 2008
    PA
    there's a hole, BUT, it comes out in a really crappy location. I just deleted mine in pcm. I also had/ have an issue with the downpipe hanging low. I have no idea why they built them like they did, but it hangs down really bad. Mine dented in once when I bottomed out, hasn't done it since. I would recommend some header wrap while you're at it. Help keep the engine comp temps down some.
  12. #12 Re: getting headers. what do i all need?
    Minnesota
    A buddy to help is nice lol, new gaskets RTV
  13. #13 Re: getting headers. what do i all need?
    Topeka, KS
    I don't think he'd say that if you couldn't put it there.
  14. #14 Re: getting headers. what do i all need?
    Willoughby, Ohio
    as long as its in the exhaust before any other component there shouldnt be a problem right?
  15. #15 Re: getting headers. what do i all need?
    Dec 2008
    PA
    Hmm, that would only read the front bank... wonder if that would give a different reading. I would want to be reading both, especially if you are tuning off of it.
  16. #16 Re: getting headers. what do i all need?
    FYI, S&S headers only read o2's off the front bank and my car ran just fine.
    besides, anyone that knows anything has a wideband in the downpipe and is tuning off of that, not the narrowband.
  17. #17 Re: getting headers. what do i all need?
    Odessa, MO
    ZZP's Stainless Headers. Note the location of the O2 bung.
  18. #18 Re: getting headers. what do i all need?
    ^^PeYaH!
  19. #19 Re: getting headers. what do i all need?
    Dec 2008
    PA
    hmph, guess its fine then
  20. #20 Re: getting headers. what do i all need?
    MA
    I just finished mine the other day. Its not a bad job at all. FYI make sure you test fit all pipes together first before installing them, mine and many others have had issues with them not fitting together right. Also make sure you have your O2 extension or are ready to soilder some Ladded length to yours. I added 15" and it worked out perfect. I also used the gaskets alon with the factory ones that were on the car and have had no issues at all and I acctually liked the gaskets they came with. My P/O though. Lower the rear part of the subframe, it makes life so much easier when dropping the rear header in, all you do is back off the bolts in the back section enough to drop like 2-3", dont remove them all the way though. I also used air tools so it made it even faster to do. All in all its not a bad job to due. Oh yeah another thing to note is I had to drill out the exhaust flange on my cat back to accomidate the larger bolts that the headers come with. Make sure you use copper RTV and even use it at the back flange too. Have fun.....
  1. Which headers to go with?
    By DEC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2013, 11:19 AM
  2. How much HP do headers add....
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2010, 06:37 PM
  3. headers
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2009, 10:19 PM
  4. headers
    Last Post: 07-10-2009, 01:36 AM
  5. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
