Thread: High rpm engine problem
Results 1 to 20 of 29
  1. #1 Re: High rpm engine problem
    GT Level Member backinblackgtp's Avatar
    Nov 2009
    centereach, NY
    i dont even know what the ICM is, how can you check it?
  2. #2 Re: High rpm engine problem
    Not sure how it's controled but isn't the fuel pump a dual pressure system for when it boosts it goes to a higher psi or something?
  3. #3 Re: High rpm engine problem
    St. Louis
    Quote Originally Posted by backinblackgtp View Post
    ICM= Ignition Control Module. This is the part that sits below all the coils and has the large wire harness connected to it. No idea how to test though besides swapping in a known good one.
  1. Engine problem 3.4L dohc
    By sheepeater in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-08-2010, 11:49 PM
  2. Engine Misfiring @ High RPMs
    By skiderek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2010, 05:57 PM
  3. 98 GTP high idle problem
    By mikegtp in forum General Tech Discussion
    Last Post: 10-09-2009, 02:05 PM
  4. engine idling high
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2009, 11:49 PM
  5. Engine problem???
    By WHITEHORSE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2009, 11:11 PM
