Thread: blinkin SES then steady fixed
Results 1 to 9 of 9
  1. #1 Re: blinkin SES then steady
    Donating Users
    Idaho Falls
    No its dead stock, I pulled the plug and I am pretty sure that since I cheaped out and didn't replace the valve stem seal with a brand new one I am getting oil into the combustion chamber. Plug had oil on it. not alot but but enough to cause the problem I think. So back into the motor I go to do it right the second time
    Moral of the story, you can't get away with anything.
    I am still hoping the piston is ok. The plug is not bent or damaged in anyway. I realize that does not preclude damage but compression check was fine. I forget the numbers but they were the very close on the front bank
  2. #2 Re: blinkin SES then steady possible valve stem seal
    Donating Users
    Idaho Falls
    Well if got the misfire on #1 taken care of, turned out in I had not tightened the rocker bolt down and it had started backing off. One of those did I really do that moments. Got that all taken care of.
    Then misfire code again, this time on #3 well needed a new coil, the #3 tower actually was rusted. Got a new coil, plugs and plug wires.
    So far so good I have only driven it about 10 miles now with no codes showing and it runs good, got good power feels about right to me.
    So heres to hoping I took care of everything. Tell you what this is about the easiest east west motor I have ever changed the plugs on
  1. I messed up! Can it be fixed???
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 04-23-2010, 03:24 AM
  2. opinion on getting something fixed...
    By Evaveli in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2010, 10:37 PM
  3. all issues fixed :)!!!
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-03-2009, 04:47 PM
  4. How can this be fixed?????
    By BwolfGT in forum General Tech Discussion
    Last Post: 09-14-2009, 08:18 PM
  5. Never Got It Fixed
    By offroadfury6 in forum General Tech Discussion
    Last Post: 10-02-2008, 06:07 AM
