Thread: 20 PSI of boost!!!!????
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: 20 PSI of boost!!!!????
    SE Level Member kirkkarem1212's Avatar
    waterford, MI
    like 01GTP said. no where should make 20 psi. i know its in the right spot, its reading vac and boost. i tested it too. something is making it build up in the LIM.
    only thing i could think of is the timing. just not letting it flow is the only i can see. 15-20 psi is a sign of restriction in my eyes. im just not sure from what.
    3.4 pulley, Borla Cat-Back, Headers, 3" Downpipe, Cat Del, Volt Booster, Trasher Air Box, K&N Filter, Intense Stage 1 Cam, 105# springs, Powder Coated TB, S/C, And Fuel Rails.
  2. #22 Re: 20 PSI of boost!!!!????
    May 2008
    staten island,NY
    you had the motor apart for the cam install, maybe someone left a rag in the intake?
  3. #23 Re: 20 PSI of boost!!!!????
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Quote Originally Posted by QwikGT View Post
    Ou!!!!
  4. #24 Re: 20 PSI of boost!!!!????
    waterford, MI
    no way. that would cause more problems than that. and ive drove 700 miles on it like this. rag wouldnt make it through that.
  5. #25 Re: 20 PSI of boost!!!!????
    I vote dead rodent in the LIM
  6. #26 Re: 20 PSI of boost!!!!????
    a million spiders made a home....
    Get a scan gauge and see what your MAP sensor is reading.
  7. #27 Re: 20 PSI of boost!!!!????
    GTP Level Member
    Nov 2008
    MA
    i just dont understand why you would spend all the time/money in your car and NOT scan it, it just seems very irresponsible, i doubt your gen 3 is actually @ 20 psi...not scanning/monitoring your motor is like bangin a hooker and you just HOPE your not infected.
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  8. #28 Re: 20 PSI of boost!!!!????
    I live here. TLSheff's Avatar
    ^WIN^ ... and that sir just became my new quote haha
  9. #29 Re: 20 PSI of boost!!!!????
    GT Level Member sic6's Avatar
    san marcos, tx
  10. #30 Re: 20 PSI of boost!!!!????
    Houston, TX
    Don't worry about it, man. I just got hammered on another thread here for gapping my plugs on an unmodified engine. Happens to the best of us, no matter how careful we think we are. Sounds like they are just saying, get busy tearing it down if your not willing to scan it. But if you COULD scan it you SHOULD, "scan" what you "can", first. On with the resolution. That's all.
    No big deal. My 2 cents. Good luck.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  3. Low boost
    By jtemple54 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2009, 03:21 PM
  4. How much boost?
    By Bigbm80 in forum General Tech Discussion
    Last Post: 07-09-2009, 04:01 PM
  5. only 4 lbs boost???
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2009, 04:50 PM
